Remote Code for a Direct TV remote for RCA RV-9900a
I need a remote code for a RCA RV-9900a. I have direct tv and none of the RCA codes work.
  • Anonymous May 01, 2009
    I upgraded to a Time-Warner Cable DVR and their remote can't seem to control the RCA RV-9900A Home Theater A/V Receiver. Any helps with remote control codes?
djnick989
  • 1067 Answers
SOURCE: sharp tv 2004 model
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Posted on Jan 26, 2008
robotek
  • 1512 Answers
SOURCE: need code for direct tv for my rca remot universal control rcu600d
The product you are trying to access may be called DirecTV(different spelling). You will need to find the make of your set top box used to decode the DirecTV and then look up satelite codes in the user manual for the remote to select the correct code.
the manual for the remote can be found at
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philipsmagnavox&dv=universalremote&md=pm435&kw=pm435s&st=&ar=&dt=&so=&pg=1&file=others/philips/pm435-manual.zip
In case you dont have the book still. Good luck.
Any drama, get back to me here.
regards
Graeme
Posted on Jan 28, 2008
SOURCE: need code for direct tv remote
ALL CVODES FOR DIRECTV RC23 REMOTE
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
SOURCE: TV/DVD CODE for Emerson LD200EM8 for direct tv remote
http://www.remotes.com/store/emerson/ld200em8.html
Posted on Nov 11, 2008
Need a direct TV genie remote code for a new RCA 65 Flat Screen Model RTU6549. I have spent hours and can not find a universal remote code for this television.
The term universal pertains to the remote control, not your RCA TV. Your Direct TV remote control may not contain an appropriate code.
Jan 28, 2018 | RCA Televison & Video
RCA remote control code for Model L40FHD41yx9 Set purchased at Walmart in November, 09, Remote code was not available at that time.I cannot use my Direct TV remote properly without this code. I was told...
The code is not in your TV; it is in a compatible remote control. Your Direct TV remote control may not work. You can try using a universal remote control to find something that works.
Mar 03, 2018 | Televison & Video
I have an RCA L40FHD41 television and a Direct TV remote RC65R. None of the codes for RCA on the Direct TV website work. What code needs to be entered so that I can control the televsion from my Direct...
try these codes " 11447 11347 11781 10029 12187
10747 11147 11247 11547 10174
10679 10774 11922 11948 11958
10038 10093 11661 11917 11953
12002 10051 10090 10278 11047
11919 "
if those dont work then try this: "
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
Sep 11, 2010 | Universal Remote Control DIRECTV Universal...
Have RCA L32HD31R flat screen TV. Codes for DirecTV sat. service do not work for their remote. Do you have any additional codes for this TV?
Need 5 digit codes for Direct TV remote, not 3 digit. I have a RCA flat screen and tried all 16 codes as per instruction from online PDF manuel and none of them work for me either.
Jan 05, 2010 | RCA DIRECTV Satellite Remote Control
I need a remote code for a rca remote for the olevia remote control can you help
Unfortunately Olevia is one of those t.v. brands that is not compatible with many universal remote controls. They make a Universal Learning Remote specifically available from Olevia on their web site that may solve your problem if your universal remote control turns out not to be compatible with your Olevia television.
As for what codes you can try, there are many, and the codes depend on your universal remote control brand. Many times, an RCA code will work for Olevia televisions, so you should try the RCA codes that come with your universal remote first, before trying any of these other codes.
If you have a Dish Network Universal Remote you can use code 506 or 127.
Direct TV remote codes vary by model number on the remote control, but the following codes work with most Direct TV remotes: 506, 127, 11144, 11240, 11331, 11610
Cable Vision use code 506
Charter and Movie Box remotes you can use 1144 or 1178
Comcast codes are 11144, 11240, 11331, 21075, 10159, 10154, and 10088
Cox code is 1610
Brighthouse remote codes are 1610, 1144, 1240, and 1331
Time Warner remote codes are 1610, 1144, 1240, 1331, 432, and 1610
If none of these brands are what you are looking for as far as your Universal Remote Control is concerned, many universal remote controls will work with Olevia televisions if you use the codes found under the RCA, LG, Phillips, and Yamaha in the code listing included with your remote control.
Jul 25, 2009 | Televison & Video
Codes
i need the code # for my RCA DIRE.TV #RCR160SBM1
Mar 06, 2008 | RCA DIRECTV Satellite Remote Control
Code for 13" RCA TV
RCA 11447, 10047, 10060, 12002,
11958, 11953, 11948, 11922,
11919, 11917, 11547, 11347,
11247, 11147, 11047, 10747,
10679, 10618, 10278, 10174,
10135, 10090, 10038, 10029,
10019, 10018
good luck
please rate
Nov 11, 2007 | RCA DIRECTV Satellite Remote Control
641 people viewed this question
 Grubhead
Grubhead
