Question about Onkyo HT-SR700 System
Power, but no sound coming from my speakers, checked fuses.
It was working fine then turned it on one day and I had no sound coming out from my speakers. It show power when I turn it on but I get no sound out of my speakers. Do the speakers have fuses too, they are onkyo too. If this continues might have to use it for road kill.
  • 9 more comments
  • Anonymous Apr 06, 2008
    last night, when i turn off system then sound coming form it. But today no sound coming form it. i also install all driver again. plz. tell me the solution of this problem.
  • williamfaz Apr 08, 2008
    No sound through speakers (none of them) but it powers up. ONKYO HT R520 receiver/amplifier
  • AngieDiva Jun 01, 2008
    no sound is coming from my speakers....the green light is on...the wire is in the correct spot...but still no sound..i connected the speakers to a radio....they worked...connected them bak to the computer....they dont....wats the problem??
  • Erik Ralabate
    Erik Ralabate Jun 16, 2008
    my onkyo ht-r520 has not had sound for a year or so. So i put it up for awhilt the i pluged it it last night and it worked but then i shut it off and after that it doesnt have sound again i give up i dont know what to do if anyone knows please let me know
  • cadillac4000 Jun 30, 2008
    i have same problem power but no sound .
  • canipe Jul 13, 2008
    can't get any sound from my speakers and the dvd want play.
  • Ron Walker Jul 15, 2008
    I have the same problem as youngcity with the same device the HT-R520. I have power, but no sound. It worked after being stored because of that problem, but after hooking up an s-cable to the amp it quit. 6 months ago it happened I took it apart blew out all the components, checked all fueses, relays, and all the other thing-a-ma-giggs and found nothing.
  • lima520 Oct 31, 2008
    no sound coming from phillips fw-M55 mini Hi-Fi System
  • shashank_200 Jan 08, 2009
    no sound is coming from my speakers....the green light is on...the wire is in the correct spot...but still no sound..i connected the speakers to a radio....they worked...connected them bak to the computer.... I dont....wats the problem?
    plssssssssssss help me
  • SB 6 6 91 Mar 15, 2009
    i turned my speakers on today n da green light is on but da sound aint kumin out. i checked if all da leads were in da ryt holes n stuff n they are what cann i dooooo?
  • Anonymous Apr 13, 2009
    the speaker appears to be on but sound does not come out even with all the cords in the right places
I have power but no sound it worked fine for a little while yesterday but it stopped whats wrong wit it
Posted on Mar 13, 2009
Posted on Apr 24, 2008
Bose system in 02 altima 3.5 se. The radio comes on but no sound. Riding along a few days later the sound comes, but now its out again?
Bad solder joint in the radio. Now heat and cold controls the sound, not the volume control.
Jan 21, 2015 | Cars & Trucks
My Kenwood KVT-516 has no sound, everything else works on it. Has video, plays cd's, plays radio, switches through everything all normal but doesn't have any sound coming out. Have check all speakers, amp,...
Check to see if you have a speakers A button and a speakers B button. Cycle them both on and off one at a time with something playing. This may turn the speakers back on. In addition you can check to see if you have a second room speakers feature that somehow got turned on- if so turn it off and the sound should come back. In addition you should download the manual and search for these features to show you have to deal with them.
Sep 16, 2014 | Car Audio & Video
Speakers will not "turn on",
Hi. You might want to try a different set of speakers or try the Altec Lansing on a different computer to isolate the issue. This can tell you if the problem is with the computer's sound card or your speakers. If the speakers won't work with any PC, try checking if the wires are all good and/ or soldered properly. Be cautious while doing this. make sure the speakers are not plugged in to any power source. I hope this helps. :-)
Jun 04, 2011 | Altec Lansing ACS 251 Computer Speakers
My Toshiba TheaterView has no sound or picture
You may have overloaded your audio output with the external speakers(impedance or short wire problem?)as a result the audio out i.c maybe damaged which in turn may have blown one of several fuses in the power supply.maybe regular GMA type fuse or picofuses,you can try replacing blown fuse but if they blow right back you`ll need the help of a repairman
Nov 02, 2009 | Televison & Video
FRONT RIGHT SPEAKER do not turn on, no power
Sounds like the amplifier has gotten a surge of power and gotten fried. You will need to replace your system as there are no user servicable parts inside the unit. You can also try seeing if there is a fuse on the main speaker prior to getting a new one. Also check all connections to make sure your getting power too
Aug 06, 2009 | Logitech X-530 Computer Speakers
Speakers not working
check speaker wires are not fractured and are wired correctly or check your ground wire.......
Mar 21, 2009 | Car Audio & Video
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Yamaha RXV-730 6.1 Channel A/V Receiver
the clicking may have been coming from the relay itself, but it doesn't simply mean that the relay is faulty. clicking may also be caused by transformers, indicating that some electronic components have developed SHORT CIRCUIT. try measuring resistance of transistors and diodes near the power unit (unplug/turn the unit OFF of course) check also for the impedance of the output power transformers.
check the amplifier IC for short also.
Feb 29, 2008 | Yamaha RX-V730 Receiver
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
Onkyo HT-SR700 System Logo
1,926 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
