Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker is not functioning
Freezer temp is too cold (no matter what the setting), food freezes in veg. drawer,
I did vacuum under the unit and removed much dirt from coil.
It appears that the water is not getting to the ice maker. Water does dipense from front of unit.
ICE MAKER NOT WORKING..NOTHING JAMMED & WATER IS DISPENSING FROM FRONT..PLEASE HELP.
  • 4 more comments
  • LINDAERIC Mar 04, 2008
    Where is the water inlet valve located, We called whirlpool, and they are sending someone out on Wednsday, but O would like to try and fix it before the appt. Where are you located?
  • Anonymous Mar 06, 2008
    ice maker not getting water. I can manually add water and it will freeze and dump. The tube that dispenses water to ice maker was frozen and I used the blow dryer to melt the ice in tube. I noticed the light on the icemaker control panel was not working. What should I do?
  • needs ice Mar 30, 2008
    My refrigerator/freezer is having the same problems. The only spot in the refrigerator keeping a safe temp is the bottom drawer. The freezer turns everything into a solid block, ice cream is a big problem. The freezer is not self defrosting and the ice maker water line has frozen water stalling in the line. There appears to be ice forming on the lower wall inside of the fridge side by the bottom drawer.
    I have the temp on the freezer side turned to lowest setting and the fridge side on highest setting.
    Do you think this is a thermostat gone out? Where is that located?
    My Whirlpool is a side by side, model # GS6SHAXLS03
    Thank you,
    Gina Woods
  • Gary Davd
    Gary Davd May 11, 2010
    I am in the Cayman Islands Sorry I Wont be able to come over for a service call
  • Gary Davd
    The water valve is in the rear pull the unit out and remove the back panel look on the right side you will see a dual valve ther 2 screws hold to the cabniet pull the valve out and switch the plugs on the valves they may not fit but you can hold the plugs on the valve to test have some one press in the dispenser in the front see if it opens the valve that goes to the Ice Maker try that first
  • Gary Davd
    sounds like you have 2 problems the too cold it most likely a bad stat in the refrig section or broken damper leading into the refrig the icemaker may have a bad water inlet valve check these and let me know
I have the same problem no ice yet water comes out of the fron dispenser. I will keep trying to make it work. We only have 1 fridge so shutting it off 4 3 days is not an option.
Posted on May 08, 2008
I ended up emptying everything from fridge/freezer. Turned it all off for 3 days. Then, cleaned it out and turned it back on. So far, one week later, everything is good. I have wondered if the damper vents in fridge got blocked and froze up. Could still be defrost timer... time will tell. Thanks for all the information.
Posted on Apr 21, 2008
    Genius:
  • 1,073 Answers
Replace the cold control
Posted on Apr 19, 2008
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/gramps_bab85ce284d72c1d
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
My 12 year old subzero fridge (650) is not getting cold. this morning i discovered ice behind the fresh food drawer, removed it, it was running fine, temp 35. now tonight the temp is 51. freezer is fine....
Is it flashing vacuum condenser? Ice behind the crisper drawer shouldn't effect the temp. What is it set at? You can go to www.subzerospecialists.com and click on Tech Help for additional info.
Feb 23, 2011 | Sub-Zero 650 / O Bottom Freezer...
I have a bottom drawer freezer Samsung refrigerator (Model: rb217abw) that is two months old. The ice maker fills with water and I can hear the mechanism drop the water into the ice bucket causing the...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze, blocking or diverting the water.. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Refrigerators
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Nov 29, 2008 | GE GSS20IEP Side by Side Refrigerator
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
sounds like a frozen fill tube, easy to check pull out refrig and you see plstic tub running into top of freezer section from behind, sometimes theres a connector fitting half way up the tube, if not you have to cut tubing and install a coupling to repair cut(available at any harware store)after cutiin tube try blowin throughin to freezer, if you cant its frozen,un freezing somtimes challange, sometimes able to blow straight though the ice other timesi se hair dryer (from iside freezer where fills the ice maker itself. best way ive found is using my steam machine i bought from one of the infomercial.good luck!!!
Jan 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
373 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
