Question about HP Pavilion dv6000z Notebook
Acer laptop wont boot -- -- please help me
Hi i just found this site and it looks really good and very helpful, having browsed if for over an hour i decided to ask for help with my problem.
My laptop when turned on does the following;
The hard disk fires up the leds come on and then after about 5-10 seconds everything stops with just the power led remaining on. There is no life coming from the monitor. I have tried to boot from disk but i dont get any different reaction at all. I took it apart a month ago and tried to fix this problem but to no avail, i have since bought a mew imac and was going to bin the acer but having found this site i thought i would give it another shot and hopefully regain the use of it for my son to use.
please help, thanks again its a great web site, keep up the good work.
Regards
Mark
  • 6 more comments
  • predator1967 Mar 04, 2008
    I am just off to bed now, its 3 am here in vienna austria but i will check it tomorrow. I am sure though there is nothing visible in the screen. The HD does not seem to run long enough to enable anything to get that far. Am i missing the point? would the inverter problem stop the screen and in doing so stop the HD from moving to the boot process.
    Thanks for the quick reply i will check it tomorrow anyway, thank. By the way the fan works during all this if that makes any difference.
    Just to add to that, i took the HD to a shop a while ago and they told me it was working ok.
    I will add to this in the morning thanks again.
    Hi Again
    Ok i dug out the pc from the cupboard and proceeded to turn it on.
    The HD spins for about 2-3 seconds only and the HD led flashes once, during this the fan spins but stops at the same time as the HD.
    I shone a torch onto the screen but there is no text or anything visible at all. I also removed and re seated the HD and the Ram. The battery holds no charge at all but it is running from the mains and the power light stays on always.
    I dont have access to an external monitor at this time.
    Any further help much appreciated.
    Having taken a second look ....this time without the tv on loud....i noticed that the fan is indeed still running albeit very quietly.
  • mainty Apr 03, 2008
    I have an Advent 7036 which has been quite a good machine over the past 4 years, It has now developed a problem. The laptop was working one minute then it knockrd itself off for no apparent reason. Since then whenever i press the start button to turn it on, the fan comes on. the start up LED blinks, and the DVD disc drive also starts up as it should, but there is nothing on the screen (completly black). The hard drive repeatedly makes a clicking sound (as if its trying to start up. The laptop will not start up, any suggestions? Could it be the CPU, thats what i'm thinking. The power source is good. Please help if you can
  • pedope Apr 30, 2008
    my lptop power indicator is on but nothing display on the LCD
  • ejohnson571 Aug 06, 2008
    seems to skip boot process- goes right to "acer" screen with background. Skips the user "click-in" prior to loading desktop. Windows XP
    Thank you
  • dave_prince Jan 17, 2009
    Hi I have the same problem with my acer , can't try an external monitor because i need to get to display properties to do that... just wondering if you found out what the problem was... I never had any previous trouble with the monitor, but the HDD has been getting noisier at start up
    Genius:
  • 1,554 Answers
The lamp inverter in the screen may be out .
hold the light at an ange do you see any text as it boots,
connect an external monitor does it work.
if no light but text then likely the inverter ,
if no ext monitor activity then boot post has failed ,
memory /cpu/ etc may have issue .
Posted on Mar 04, 2008
Why inbuilt microphone not working in acer 4930
Have you got the driver installed properly? If in doubt browse acer.com for updated drivers.
Hope that helps.
Feb 25, 2011 | Acer Aspire 4930-6862 Laptop
My acer aspire laptop wont reboot
Does it not start up at all or just not reboot? MY DAUGHTER'S Aspire wouldn't start up or anything and we had to leave it on charge for several hours and it restarts and boots fine, we have found that we need to leave it plugged up and use minimum battery power for it to work correctly.
Hope this helps you please don't forget to rate/vote or place a testimonial on my advice.
Wicked Angel
Dec 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Aspire 5735 laptop has recently gone very slow to work. The Virus scan came back ok and there is plenty of memory. Laptop is really only used to browse internet and email. Any Ideas?
Hi, open the Task Manager, check (2) two areas; see how many (Services) are running, if its more than (75) seventy-five? than try to "Stop" non-essential "services' from running at "Start-up." This is also the case with "Processes" running, and the "startup of "Programs" once Booting-Up! One other thing; if you mostly use the computer for "browsing" view how many "sites" are actually "Logon," and are actively "open." If this helped? "Rating" is appreciated, thanks"
Feb 23, 2010 | Acer Aspire 5735 Notebook
My acer aspire one netbook tries to boot ,but then goes to a screen giving the choice of pressing f2 to go to setup,or to press f12 to change boot order.it wont even boot in safe mode or last known good...
i was able to go on the acer website on another pc and found that if when you turn on your acer and hold down ALT key while hitting F10 that will bring you to a system recovery screen. you can restore factory settings from there. It will wipe out all of your documents and pix but it does fix the problem.
Apr 19, 2009 | Acer Aspire One PC Notebook
Acer travelmate 2350 wont boot or display
I have seen this on several ACER Laptops. It is always the Motherboard. Contact Acer repairs and order a new motherboard. IT will likely be about $200ish dollars. Then follow one of the guides on the web for taking your laptop apart and replace the board.
Feb 15, 2009 | Acer Computers & Internet
My new acer works fine but there is something loading in the middle of the screen and i cant get rid of it .... how ?
these are system set up routines, when you first boot up Acer laptops they configure themselves, then reboot about 4 times, to load all the drivers and pre installed software, but if its taking too long (hours) then you need to speak to Acer technical, see below for tel no.s
http://support.acer-euro.com/phone.html
Aug 29, 2008 | Computers & Internet
Hi please help me with my acer 3003 wont boot
try to power up with power cord only and see if it works. If no lights turn on than your motherboard is dead. If it turns on and nothing happens make sure there is memory installed(RAM). If it turns on and you see windows screen than it shuts off than your operating system needs to be installed again. Also, you can try booting in safe mode by hitting f8 when you initially start your computer and see if it stays on and if it does you have a virus most likely. Good luck.
Aug 18, 2008 | Acer Aspire 3000 Notebook
PC not booting
Assuming the power supply is good, sounds like the ac plug where you attach the ac adapter to the laptop has been unattached from the mother board.
What model is it?
Nov 25, 2007 | Acer Aspire One PC Notebook
Aspire 3000 will not boot
Hello Halfwit, Your laptop is trying to boot from lan because it can't for some reasons to boot normally from the hard-disk. Try to listen if when you power on the laptop the hard-disk spins or makes any noises. If not there could be a problem with the connector that links it to the mainboard. If you hear a noise or the hard-disk spins then you may have a corrupted OS (windows) or some bad sectors problems. The best way to find out would be to try to boot the laptop by using a windows instalation cd. Boot from the cd-rom and check to see if the windows installer find your hard-disk and can copy files to it. You will need to change the boot order from bios to enable the cd-rom to boot first or enter some boot menu (if provided) and select " boot from cd-rom " or such thing. If you need more help with these please post back or contact me or other experts on the live chat function on this site. Good luck.
Mar 23, 2007 | Acer Aspire 3000 Notebook
HP Pavilion dv6000z Notebook Logo
226 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
