Question about Denon AVR-887
Denon avr 887 input problem
My receiver has been working great, one day the speakers started to squeal and then silence. I realized the input display was cutting in and out and finally staying out. After numerous variations of cable changes, input modes and aggrevation, I started to here the input circuit clipping. It tries to come on, but nothing. Microprosser has been reset, didnt help. Initial turn on everything works for about 5 min. Any help with this problem would be greatly appreciated. Thank You
  • 1 more comment
  • sunraisen2 Jul 28, 2008
    I have a Denon AVR-887 and inconsistently the sound will cut out and the speaker will squeal. Usually turning the unit off and then back will help, usually though, this is temporary as it will sqeal again within a few minutes.
    I have reset the miroprocessor and checked and rechecked the wiring, I even sent it to an authorized Denon service center. They said they checked it for 3 weeks and no problems, well when I got it back after a few days the damn sqeal again. Help! Before a take sledge hammer to this thing!
  • borisbeddeno Jan 26, 2009
    I've had mine for a year and a half and no issues.  I just moved and plugged everything in and got pretty much the same issue.  At first I had sound and as I switched through the various modes, one sent my speakers to squealing. I re-plugged everything and I got sound for about 5 minutes before the speakers started to crackle a little bit before total loss of sound.  I have not tried to reset.  I too am in need of help.
  • 3dconge
    3dconge Feb 16, 2009
    I've had my Denon AVR-887 for a couple of years now and only in the past 3 months has the audio sporadically started to cut out and then the speakers squeal. Resetting the unit does help, but as others had stated, this is temporary and sad way to keep the unit working.
    This happens no matter what mode I have it in. I've also reset the microprocessor, checked and rechecked my connections.
    The one thing I changed last night is I added large felt pads to the feet to get more airflow under the unit. I've also raised the shelf I had above the unit. It did had ample clearance before (according to the specifications in the manual, but now I've giving it another 3 inches of breathing room. I will report back here if I find out this helps.
    Seeing others with the same problem is somewhat comforting, but also discouraging. This will be my last Denon purchase.
    Problem Solver:
  • 3 Answers
Sell it on Ebay and buy a new 2309.
Posted on Jul 29, 2008
Well it's been 2 weeks since my last post about having the same problems. No static, popping sounds or complete loss with a single tone! WooOoOoOo! Turns out it was airflow only. I have about 6" headroom above the Denon now and I also leave the door open on my media center (glass) whenever I turn on the Denon. Also of note, my media center has an open back.
Posted on Feb 26, 2009
  • 3dconge
    3dconge Mar 16, 2009
    I take that back. My unit is now failing all the time all of a sudden. LEMON. Anyone want to by it for spare parts?
I have recently experienced front left, center and front right speaker audio output problems. First it was the front left completely off. I would wiggle wires in the back thinking it an input cable issue. I changes my HDMI cables, but this did not apparently change the symptoms. I resorted to gently tapping on the cabinet and noticed audio changes in the front 3 speaker levels including hum from the center speaker with weak sound.
A long story short, I used the speaker levels tone test on manual to check the levels while tapping, slapping then almost pounding on the rear top of the receiver in an attempt to restore my front 3 channel outputs to their full volume levels. I am now convinced that the problem lies in poor connectivity between the power amplified modules and the speaker output terminals. I have seen this in Pioneer receivers and actually resorted to re-soldering the modules to the circuit board after seeing cracked and open solder joints. Without knowledge of the internals of the AVR-887, I am confident this is a similar scenario and I will have to g inside to effect the permanent repair. Not looking forward to disconnecting and reconnecting my A/V plant and the risk I will have to reprogram inputs etc. to get it all working again. Such is the bother for an A/V hub setup in a cabinet.
I wouldn't look for anything more complicated such as the internal processors and A/V switching circuitry. The highest current pathways are the most susceptible to this breakdown for audio output. However, if anyone has found another problem area, please let us know!
Posted on Jul 17, 2010
Denon avr 1311
This could be just a faulty headphone socket. Unless the headphone socket has a built in pre-amp stage.
Jun 01, 2013 | Audio Players & Recorders
Denon avr-887 code for comcast silver remote, red key. The 2 codes comcast gives me do not work. Any other codes known?
These are the codes that I have from a few extra sources. They are for ALL Denon receivers/tuners: (3 digit = 262,307)For the AVR all numbers consisting of a 4 number code, all begin with a "5". Here they are: 5006, 5048,5054,5085,5129, 5130, 5131, 5132, 5133, 5134, 5152, 5159, 5160, 5168.I was able to get my 529 rc to program some of the features but I will go back and try other codes that may have a better "fit" and operate more features. Hope this helps!
Sep 05, 2012 | Denon AVR-887
Where is the fuse in a denon AVR-887
It has to have one---follow the power cord inside the unit--if fuse is good consider taking it to a shop for an estimate.
Jun 17, 2012 | Denon AVR-887
Denon AVR-887 turns itself off in 5 secs, any one know why?
You might have the polarities on the speakers crossed, check all speaker connections to make sure the pos and neg are connected correctly. If they are crossed, this will cause the receiver to short out, thanks
Apr 05, 2009 | Denon AVR-887
Denon AVR 1506
Try this, turn off the unit and remove the AC power cord from the electrical outlet, Hold the AUTO button and PCM button and plug the unit back into the electrical outlet, if the display starts flashing with 1 second intervals then release the 2 buttons, this initialized the microprocessor
Feb 09, 2009 | Denon AVR-1506 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Denon AVR 887 Upconversion With Wii
I have this hookup and it's working almost perfectly:
Wii --component--> Avr-887 --HDMI--> Sharp LCD TV
Sometimes the pictures don't show up during start up, but I figured it was (probably) due to Sharp's HDMI handshake issue, so I turned the TV off and then on, everything works.
Mar 20, 2008 | Denon AVR-887
Protector flashing
first check speaker connections for a short.Something usually is touching either at the reciever or amp.The receiver goes in protect mode when there is a short.If that does not work the receiver may be trying to push more watts than capable
Jan 01, 2008 | Denon AVR-887
Denon AVR-887 and Wii
I'm dealing with the very same frustration. Best I can tell, the problem with my setup is that this model (avr-887) can't pass component video input out through HDMI. Can anyone confirm that?
Prior to setting up the Wii, I'd only been using a single HDMI output from the denon to my tv/monitor.
The only solution I've found is to add a component video output to the monitor -- which is unfortunate. I'd much rather have only the single HDMI out.
Would love to hear if there is a way to set this up without having to add the additional component output...
Dec 26, 2007 | Denon AVR-887
My Denon AVR-887 Keeps turning itself off
I have one and the same thing happened. try resetting your microprocessor and if that does not work, then check the wiring of the speakers. if that is working fine and no wires are touching then I unplugged everything and was still having the issue. took it in for service and it was found that the transmitor was shorted as the speakers that I was using was too high in ohms. it is possible that it could be your caps also if resetting the microprocessor does not help. You can find out how to reset the microprocessor from your manual. If you have the Denon avr 887 with the system turned off hold the power on button and the speaker A and B at the same time for a few seconds. This is compatible to rebooting your computer. Hope this works for you as this was and is my husbands favorite past times.
Dec 01, 2007 | Denon AVR-887
Denon AVR-887 Logo
390 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
