Scanning problem to .pdf
Before I scan to .pdf format I have to open Adobe, click help and do a repair of the installation. If I don't do this my text is only partially legible (large chunks have lines going through, much like a bar code you scan at the store). I've tried doing the repair, scanning/saving one set of documents and then scanning/saving another set right away. The first scanned/saved image is fine; the second is as described above. Should I just uninstall and reinstall the adobe? I have installed the most recent free version and checked for updates as recently as 3 days ago (none). Thanks in advance.
  • 2 more comments
  • CMJMail Mar 04, 2008
    No. I scan and send a lot of documents anywhere from 10-40 pages 2-4 times a week. If I were to use FoxIt Reader, how would it work if the person on the other end uses Adobe? Is a .pdf, a .pdf, a .pdf? If they need to be able to edit the document will it matter if I use FoxIt and they use Adobe?
    Thanks -
  • a67994 May 11, 2010
    Also, Do you have a FAX?
    If you do their are ways to FAX 2 EMAIL as PDF
    Remember all this is up to you if you like how adobe works I wouldn't change it
    your probably going to have to reinstall if you stick with adobe
    now that I double Check you would need FoxIt Creator for that which is free but would put Evaluation at the top of your file so that is up to you. But, yes a pdf is pdf no matter what program you use it is only their to tell that computer your sitting at what program to use.
    If you're using the free edition of adobe successfully for this long at that rate I would stick with it and do a complete uinstall from add/remove programs in the control panel and reinstall from adobe
    Some Scanners also can directly Convert Scans into PDF it depends on what scanner you're using where it say's save as type see if it has pdf
    Have you tried FoxIt Reader?
    If you do decide to reinstall adobe make sure you remove it using add/remove from the control panel
    Problem Solver:
  • 5 Answers
plz re install adob but before that plz un stall it from the control panel
Posted on Mar 04, 2008
There is no option to scan as pdf on my 4625 HP scanner (tif, jpg etc are available), how can I add pdf?
The HP SCANNER SPECS say: Scan file format Bitmap (.bmp), JPEG (.jpg), PNG (.png), TIFF (.tif), PDF (.pdf), Searchable PDF (.pdf), Text (.txt), Rich Text (.rtf).
That means it is supported. What you can try is to try and uninstall ("Programs and Features in Windows) the Adobe PDF program and get the free one to install again from: http://www.adobe.com/products/reader.html
If it still doesn't work (links itself into Windows and the HP software), try reinstalling the HP software or go to HP.COM and you can download the latest full-version file for your 4625 printer.
Dec 02, 2013 | HP DeskJet Office Equipment & Supplies
1) whether the scanned document from this multifunction hp laserjet printer be saved in PDF format. 2) whether continous scanned pages be saved as one file/document.
The answer is yes to both questions. Follow the instructions below:-
Go to Adobe Acrobat. Click on FILE. Click on CREATE PDF. Click on FROM SCANNER. Click on SCAN. You should now be scanning your first page, after completing it you will be asked if you want to scan any more pages or close. Select to scan more pages till finished. You can also select to have Acrobat do an OCR after the scan which will allow you to search the document. To do this, click on DOCUMENT, click on RECOGNISE TEXT USING OCR and click on START
May 10, 2011 | HP LaserJet M1005 Printer
How to scan a document in pdf format from hp psc 1315
  1. Position the first page of your document on the flatbed scanner and close the lid.
  2. Step 2 In Adobe Acrobat, under the File menu, choose "Create PDF", then "From Scanner" and then "Custom Scan."
  3. Step 3 In the Scan dialog box, choose your configuration settings. This will vary based on the nature of the document you wish to scan (e.g. color or black & white, images or text).
  4. Step 4 Click "Scan."
  5. Step 5 When the scanning process is complete, Acrobat will ask you if you wish to scan more pages into the file. If you do, position the next page on the flatbed scanner and click "Scan More Pages." Otherwise, click "Scan Is Complete."
  6. Step 6 Repeat the above steps as necessary to scan a multi-page document.
May 30, 2010 | HP PSC 1315 All-in-One Printer
I have an HP Deskjet F4440 that will print/scan/copy. But when I scan a letter and open the file it is in a format that I can't read. How do I scan a letter and put it into a format that I can read?
You need to scan into a Word Processor, like, Word or Adobe PDF, or Publisher, you need OCR (Optical Character recognition)software to have this. Scanners usually ONLY scan as Pictures. and save as Picture files, BMP, MPG, TIFF. NOT as text.'
Mar 02, 2010 | Office Equipment & Supplies
Is there a way I can scan to pdf? It worked
HI
If u try to scan from sollution centre, on the home page if u click on scan a document, there u will get an option of file format select pdf and click on scan.
make sure the u have adobe reader install in ur pc
Nov 13, 2009 | HP Photosmart 3210 Printer
My Dell 968 printer does not scan to PDF format. How do I do this?
hi there !
-you need to have a PDF reader like Adobe Acrobat Reader
-if you have the program already; you need to include the program in the printer scan settings
-you need to open the Printer program then click on the scan category and select the Adobe program and set it as default to have a pdf format.
Oct 24, 2009 | Dell 968 All-In-One Printer
How do i scan multiple pages
Please perform the steps given below to scan multiple pages to a single PDF file.
NOTE: Before performing the steps please make sure that Adobe Reader is installed on your computer. If not installed then goto www.adobe.com and install Adobe Reader.
  1. Open HP Solution Center.
  2. Click on Settings.
  3. Click on Scan Settings.
  4. Click on Scan Preferences and Select the option 'Prompt for additional scans when preview is turned off'.
  5. Click on OK to apply changes.
  6. Now Click on Home and click on scan Document
  7. Select Document to File under scan shortcuts.
  8. Uncheck the option Preview Scan at right bottom of the scan window.
  9. Now Click on scan to scan document.
  10. When prompted for additional scan place the another document on scanner glass or ADF and Click on Scan.
  11. After scanning is complete Click on Finish to save the scanned document
  12. To Locate the scanned document (PDF) goto My Documents folder and Open My scans folder.
Oct 12, 2009 | HP Officejet 6500 Wireless All-in-One...
Want to scan in a text document and edit it in microsoft office I have a epson Dx8450 scanner
you need to see if your scanner has any OCR software. If it does it needs to be scanned and processed through it to create a document you cane dit.
Oct 04, 2009 | Office Equipment & Supplies
Doc chnages required
You can't.  You could try loading the Adobe professional software, but I do not think it lets you edit PDF's
If the Doc contains words you can OCR (Optical Character Recognition) it (ie read it) edit it an dthen create a new PDF.
Jan 14, 2009 | Microsoft Computers & Internet
Software to convert word document to pdf form
Hello sir,
Try the software DESKPDF. it can any convert any format to PDF file. U can get this software from http://www.docudesk.com/ with trial version. After installing the software u just drag the scanned image and drop the icon of deskpdf software. It will convert the pdf form.
Best of Luck
cheers!!!!
Feb 09, 2008 | Adobe Acrobat 7.0 Professional
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
