Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Icemaker won´t work
I have been trying to fix the icemaker with no success, following the instruction sheet that was behind the kick plate.
finally I removed the icemaker, hooked a volt meter to the two bottom pins of the plug that connect to the icemaker and closed the door. I am not getting the110V.
Also I tried hooking the icemaker to 110 outside of the fridge and the motor works fine.
When I perform the Ice maker diagnostics procedure, I get to the step #7 (with T and H jumpered) but the icemaker won´t start. There is no voltage feeding the icemaker.
What else can I do?
I am living out of the US so it´s not easy to get spares. I need to fix it.
thanks.
  • vvvzzz Mar 06, 2008
    i already tried that but there is no voltage going to the ice maker
  • Anonymous Mar 08, 2008
    I only have 45volts to the ice maker
Remember you must press the button to simulate the door closing when jumpering T & H or it will not turn...
Posted on Nov 19, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
If you got 110 volts to ice maker. try jumping out the T & H ( a small insulated copperwire) . this will cause the ice maker cycle, if this does nothing replace the ice maker.(entire assy cheaper then the parts). remeber you might have to shut the door switch to get the 110v. some machines run the power through light switch
Posted on Mar 04, 2008
  • Ron Coons
    Ron Coons Mar 07, 2008
    where you got the ice maker tech sheet should also be the main tech sheet with a wire diagram. you would need to trace out the wire leading to the harness. power to that harness should always be present
PLUG LEFT IN WHEN PULLING AWAY FROM WALL. NEED DIAGRAM TO REWIRE PLEASE
Most have a tech sheet located behind kick plate sometimes taped to bottom behind plate but you can go to sears parts.com and view wiring diagram
Mar 25, 2016 | Refrigerators
My undercounder KUIS18NNJB5 icemaker freezes successfully but the ice does not exit the freeze plate completely during the harvest cycle. When the next ice cycle starts, the ice refreezes to the plat
In the manual the fix is to clean the ice maker with cleaner. Your ice slab is not releasing during harvest. The plate (evaporator) has minerals on it and needs to be cleaned to remove the build up. On the door of the unit has cleaning instruction, do not short cut the cleaning process, this does take about an hour and follow the instruction to the letter.
This is not a major issue, just cleaning is needed.
Dec 07, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
Won't work say's clean
the clean light is flashing a error message , remove kick plate and get the tech sheet to see what the error is .
Feb 20, 2013 | Kenmore Dishwashers
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
Mod.# ggw9200lwo display says control lock, dryer won't work.
You may have inadvertently locked the operator console. This is actually a built in safety feature that allows you to lock the operator control panel to keep small children from manipulating the controls. The following link explains how to correct:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are for most Whirlpool manufactured front loaders. This includes Kenmore and Maytag models too. Keep in mind, all washers do not have the same control features. If your features differ from the ones I have outlined, the instructions should be either printed on the front panel, or in your technical data sheet. The tech sheet will be located inside the washer behind the lower kick panel. If not behind the lower panel, it will be affixed to one of the interior cabinet walls.
If you require further assistance, please let me know. I hope this has been helpful to you.
Aug 19, 2009 | Dryers
Water coming from new refrigerator water dispenser is not cold
CHECK TO SEE IF THE DRAIN LINE IS CONNECTED TO THE PAN BEHIND THE KICK PLATE. I would offer a diagram but I'm in search for one myself.
Jun 16, 2009 | Refrigerators
Frigidaire side by side fridge/freezer
Try checking the evaporator fan. The blades are just pushed on and sometimes may work itself up or down and plastic fan could be rubbing.
Apr 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Catastrophic electrical problems
I'd check the terminal connections and twist them a little to see if they're loose or corroded.
Then follow the wires and check all other connections from the battery.
Can you jump start it?
If not it could be the solenoid or something else!
I once had this problem and finally discovered it was a melted connector under the dash on the drivers side right below the ignition.
I hope this was helpful!
Good Luck!
Jan 20, 2009 | 1991 Oldsmobile 88
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
269 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
