Panasonic DPC262 laser printer. We want to print compressed test (132 char per line) from a DOS program - is there an escape code for this? I have tried 27 40 115 52 83 from another printer but that desn't work.
  • 181 Answers
Well the problem is the laser printer - you need to insert in your program, the control (or escape) codes to set the condensed mode ON. Usually printer manuals come with that information (or used to come). But since laser printers are graphical devices, they are not designed to provide access to font changes without a windows driver.
In other words, you'll need to update your printing engine, so it can be compatible with a windows-based printer. Those printers accept information in graphical mode, instead of text mode.
An alternative method, could be, print your output to a text file (not to your printer). Then, open the output file in wordpad or even Word. There you can apply different type fonts and print from there.
I hope this helps, unfortunately the laser printer technology is not compatible with ms-dos applications, by design.
Posted on Mar 04, 2008
    Genius:
  • 1,226 Answers
Hello!
I guess this printer is not supported, Please rtefer to your manual for this test.
melnavz
    Sergeant:
    Champion:
  • 281 Answers
DQTUN20M - DQ-TUN20M
Panasonic dpc262 cannot establish network connection
Look into whether you have the correct router access password.
Oct 05, 2010 | Panasonic DPC262 Printer
The printer cannot be set to a page length when printing from a dos program. The page length is incorrect but changes with every print even though the same file is printed
Prints from DOS programs do not have a "page length" setting of their own, nor do dot matrix printer have a page length of their own.
Page feed is achieved by sending a special control code (^L), and the meaning of ^L can be set through specific escape codes that the DOS program has to know.
My guess is that you need to tell the DOS program the page size in lines or inches, and maybe instruct it to send a page feed command after each page.
You can try directly programming the printer, but if the DOS program is sending out the wrong codes, this is not going to help. Anyway, here goes. Good luck!
http://www.masondesigns.com/staging/dhl/printer/lasernet/turboset.html
Feb 01, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Extra Line when printing from a dos-based program
your printer paper size shorter than your PC dos-program print size setting, example: if use a letter size paper to print a A4 size file which should occur two paper go out..
so you need check your PC print setting or take a presetting paper size, make a size match between PC program and paper in printer .
hope you fix it, please take a rating let me know how much helped you thanks!
May 21, 2009 | Dell 5100cn Laser Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printer doesn't work
it seems to me that you might gotten the wrong driver install in your system.
error page - Position: )x42b (1067) System: h6fwaim_mono/xl_image Line: 132 Version: QPDL 5.04 04-25-2005
do a check on your OS version. Operating system. right click mycomputer icon -> properties.
download the correct version of driver from Samsung website again. uninstall the currect version and unplug the usb cable to the printer.
restart your system, install the downloaded correct version and plug in the usb cable to the printer. do a custom install to serach for the printer. if it does search the printer. it will show you. USB001. after install you will be prompt to do a test page. test on it to see it works.
if it does not work after downloading and install the driver. You might have a mainboad firmware corruption.
to run a firmware update is not easy it might course other major issue. only install by an trained Samsung Engineer.
Hope this Help :)
SamsuTech
Sep 20, 2008 | Samsung ML-2510 Laser Printer
well..that EOJ line, is possibly farther down in the program settings, and is like a page break. the Dell is only doing what it's reading, so the answer is in the programming of the application. Perhaps you might query that company about how well that program interfaces with the Postscript quality printer you have?
check your computer warranty here for FREE
Feb 26, 2008 | Dell 3100cn Laser Printer
INTERNAL ERROR--FALSE
My printer was able to print an "INTERNAL ERROR - FALSE, Position: 0x1227e (74366)" error message as well as a test page, but not documents sent to print.
However, the problem was fixed once I switched to another USB port as the person above mentioned. So for any other people with similar problems, try that! In addition to power cycling the printer (I did that first)
Jan 23, 2008 | Samsung ML 2010 Laser Printer
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
