I have an RCA model 27V530T and I cannot seem to get a signal in order to connect the television to my DVD player. I made sure all the cables were plugged into the right outlets, but when I do the television says "Unusable Signal" What should I do?
    Scholar:
  • 133 Answers
Some of these sets have had loose connections internally on the A/V module . Or if you think you can do it yourself . This module can be unplugged and take it to your local shop to have the solder contacts resoldered . This chassis is very tricky to get out . If you do not want to try call around to get an estimate onhow much they'd charge to do this procedure . We'd charge around $50.00 to $60.00 . Good luck
Posted on Mar 04, 2008
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
The input dvd screen says no signal and the DVD player doesn't seem to have any power.
If it is in warranty return it---parts for the DVD unit are not available--they would have to replace the entire DVD unit inside the set.
Mar 12, 2012 | RCA 32LA30RQD TV
I'm trying to connect my DVD to the TV I can hear sound but can't get a picture and I get the message 'no video signal'
Connect the yellow video cable from DVD player to TV's yellow video input. See diagram below. Connect white RCA audio cable and red RCA audio cable as shown. Be sure to select the proper input on the TV.
Apr 08, 2011 | Toshiba 26AV500U 26 in. LCD HDTV
Had to get new DVD player as old one packed up. Connected one year old Samsung television receiver LA26B450 to new Philips dvd player DVP3560K but gives no colour, only black and white. Have checked...
to put this simply ive spent almost all day advising on this exact problem have alook at my fixes and it will show you the problem but to put it simple you either have connected the wrong cables ie-- rca vs caroma the best way to fix this is to correct the setting in the output on your dvd player it needs to know what signal to send the tv ie rca caroma or hd cable
best of luck let me know if you need further help
sonic boom electronics
Dec 28, 2010 | Samsung SP42P2S Television
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
I am having issues with my RCA L46wd22yx5. First cable is on channel 3. that channel keeps saying unusable signal. Video 1 is the DVD player. Same thing..Video 2 is the Xbox 360 same thing and the HDMI1 is...
Check to make sure that the individual cables are connected to the corresponding channel. For example, DVD player is connected to the "Video 1" output on TV. On the back of your DVD, the cable is plugged in the "out" output, going to your TV the cable is plugged in the "in" output(red, white, yellow) Are you using an RCA cable(red, white, yellow) for the units?
May 13, 2010 | RCA L46WD22 Television
Can not make the instalation betwen my tv and my dvd player
Most DVD players today have only RCA jacks for video and audio outputs, and don't have RF (channel 3 or 4) outputs. If your TV doesn't have AV input jacks (either too old or just not supplied on your model) you can't connect the DVD player directly. You'll need to get an RF converter to make the connection.
An RF converter costs about $15 and you'll find them where you can buy TVs. The converter takes the video and audio signals from the DVD player and creates a channel 3 or 4 output signal to your TV. If you don't have the cables already, make sure to get them too. You need a "dubbing cable" (RCA plugs on the ends, usually color-coded red, white and yellow) to connect the DVD player to the converter input jacks and an RF cable with "F connectors" on the ends for the output to the TV. Often the dubbing cable comes with a new DVD player, and the RF cable with the RF converter.
If this takes care of your connection troubles, please take a moment to give my solution a good rating. If I've missed something and can be of more help, please post a followup comment.
Mar 31, 2009 | Symphonic ST4819 19" TV
No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Feb 06, 2009 | Toshiba 37AV500U 37 in. LCD TV
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
Unusable Signal
I have exactly the same problem, with my RCA F27645. I can find no answers on the internet, so far.
I have 3 ideas.
1) The digital signal receiver must not be receiving the DVD signal properly.
2) Coaxial cable receiver (the little pin plug) problem
3) Digital TV (broadcasts) causing havoc on older TVs.
Mar 27, 2008 | RCA 27V530T 27" TV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
