Question about Brother MFC-640CW All-In-One InkJet Printer
I need help installing my printer
I cant locate the ink place where to put it plus i cant find the usb plug place to hook it up? help.. Is there somewhere online it can show me where everythign on the printer is?
    Master:
  • 351 Answers
Dear Angie ,
You can download User Guide from this link:
http://www.retrevo.com/s/Brother+MFC-640CW?rt=pd
It will helpful to you operate this machine smoothly .
Cheer up and Enjoy urself
Posted on Mar 04, 2008
What kind of usb plug i need for lexmark8350 to hook my pc
The USB cable would be the standard A/B cable. the port on the back of the printer, is located under the phone line jack. Open the attached URL for the setup guide.
http://www.lexmark.com/publications/pdfs/8300/eng/setupsh.pdf
Mar 16, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
How to network hp laserjet4 plus with dlink 628
Go to HP.com for the exact directions, for free. But in essence, you do NOT plug and play, but rather follow the install directions exactly.
Usually you are directed to eventually hook up the printer via USB, and the software makes the printer connect when you hook up the network cable.
ALL computers need to run the install after that "host like" process. Remember to remove usb connection when you are done.
Then install and navigate to the newtork location of the printer, on each machine in your network.
Oct 24, 2010 | Computers & Internet
Cant find where it gets power from - stupid to some but ???
Take a look at this:
The Power Button is indicated as "Power/Resume button"
Any problem? let me know.
Good luck.
Thanks for using FixYa.
Jul 29, 2010 | Lexmark Z600 InkJet Printer
My HP Officejet All-in-one printer is not hooked up to the computer, after I changed an ink cartridge. HELP!!
The first thing that I would advise you to do is,
Put off the printer,
Uninstall the Printer Software totally from the System first,
Restart your computer,
DO NOT connect the printer yet.
Re-install the HP Printer software that came with it.
If you don't have it again the you can easily download it from HP Website in the support section.
Wait until it reaches the stage where you are asked to plug in your printer.
Then Locate a USB 2.0 Port on your computer, but make sure it is not the port that you normally use to connect the printer to your system before.
Plug it in and let it do the rest.
Try this out and let me know how it goes.
Hope this helps.
Good luck
Nov 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant download cd once it comes to the part to hook up usb it freeze up
What OS are you using? After the CD install is finished (or error out), unplug the USB cable and plug it back in. If you get any Plug and Play prompts point to the correct Scanner driver under "Scan" folder and Print Driver under - "Win_XP2K" folder on the CD and let it finish install that way. See if this helps.
May 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
How do I hook up my epson stylus cx6600 to my computer
Kenney,
The usbport on these printers is located under the scanner assembly. Open the top of the unit as though you were going to replace a cartridge, To the front you will find the usb port. Be sure to thread it through the cable slot.
Gremlin11
Please remember to rate my assistance!
Dec 13, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Dec 12, 2008 | Epson Stylus D88 InkJet Photo Printer
Help
could you try another cable, maybe the cable is the problem. If not, test the port if it detects other devices. If not disconnect the printer and install first the driver and then when it asks for the printer, hook it up.
Jul 05, 2008 | Lexmark X7350 All-In-One InkJet Printer
None
I presume that you have sucessfully unpacked the printer and put in the Ink cartridges.
You put the install CD that is provided with the printer and when it asks you to connect the printer via the USB cable, you insert one end of the USB cable in the printer and the other end in the USB port of your PC.
Dec 25, 2007 | Canon PIXMA MP160 All-In-One Printer
Brother MFC-640CW All-In-One InkJet Printer Logo
43 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
