Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to create my own layouts? - Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Anonymous
Level 2:
Guru:
  • Expert 184 Answers
  • Posted on Mar 02, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
184
Questions
Helped
53937
Points
820
Both the MTX8000 B5 & B7 models are Type II Trunking. If you are (un)lucky enough you might find an F3 modem that does Type II.
If it is an MTX8000 and has a front mounted display with either a 6 button or full keypad, you have a radio that will do Type II.
There were a few B3's that were Type II produced by Motorola. However, you can clone a Type II code plug into a B3 radio and it will work just fine.
You can run system watch using a MTS2000 handheld. Firmware version has to be above 5.44 (which has a 512k controller in it). Most MTS2000/MTX8000's only have a 256k controller, which will not work. You can put the radio into RF modem mode from the F4-F4-F4 (Trunking Config).
NOTE: When the radio is in the RF MODEM mode, it will do a self test and then the screen will go blank. The radio DOES NOT have to be programed to the system you want to watch. You set SYSTEMWATCH to the Spectra with RIB mode (works best). Even watches Type I systems.
If you have the accessory adapter for the side connector on the radio, the typical schematic of the speaker mic looks like this.
If you are using a Public Safety speaker mic with the radio, you might want to order part number 3205514W01 to cover the antenna connector on the radio.
If you are trying to program a MTX-838, from what we've heard, you need to use the MTSX software. The RVN4097F ver R02.10.01 RSS package specifically shows it programs the following radios: MT/MTS2000 MTX838/8000/9000. Now, the update for this software is RVN4097M R06.00.00 05 Sept 97, which should mean that it should program the radio as well. The cable you need is the standard MTSX programming cable.
Do you want to build your own programming cable? If you don't want to use an old speaker mic cable, see the individual part numbers of the parts for the Service Cable, below.
You may want to look at the schematic for the RKN4035D Service Cable. This is the actual Motorola cable used for programming and servicing these radios.
The individual part numbers for the components of this cable are listed below.
how to create my own layouts? - jedisvcpt.gif Reference Part Number Description C1 21-84008H06 Capacitor, 33nF 1 09-84538E03 Receptacle, 25pos 2 15-80349B36 Housing, Connector 3 30-05118W01 Cable, 13 Conductor 4 01-80754A26 Plug Assembly 5 42-10217A24 Strap, Tie 6 38-80373B24 Protective Cap 7 04-10058B12 Washer, Nylon 8 42-05184R05 Strain Relief 9 22-05541V01 Pin, Latch 10 41-05538V01 Spring, Latch 11 55-05536V01 Latch 12 15-05691W08 Housing, Connector 13 32-05533V01 Seal, Baseplate 14 32-05472P11 Gasket, "o" Ring 15 64-05241X01 Baseplate 16 39-05895V04 Contact, (13)
Serial#4585680
Serif: Web design, photo editing and DTP software
www.serif.com/
WebPlusThe leading independent publisher of award-winning, great value software. Download our web design, photo editing, desktop publishing and graphics ... every pupil to create professional graphics, video and multimedia in every subject.Missing: serial ‎4585680
Music-, Video-, Graphic & Photo Software from the market ...
www.magix.com/
MagixMultimedia software for editing and creating photos, videos and music. ... The perfect desktop publishing program for creating your own logos, business cards, ... Image editing and graphic design in a single program: Give your photos a special ...Missing: serial ‎4585680
Flexi layouts 2 full crack serial - בית ספר לכדורגל מכבי תל אביב
www.golball.co.il/flexi-layouts-2-full-crack-serial/
Upgrade keygen patch. boost and visual design multimedia software. ... Http: senderserial, full movie layout cut graphics publishing, Full color digital graphics ...
ID card layout
You can create a layout for ID cards with Microsoft Word. If you want a more graphical design, you might want to try InkScape or Adobe Photoshop.
What is the function of layout in microsoft powerpoint?
The layout is the way you want the presentation/doc to appear. Is just like the frame for the paintings, but includes the settings like type of texts /fonts/images and so on ..you can use in your work.
Check this if you want to know how to work with layouts in Powerpoint:
  • http://office.microsoft.com/en-us/powerpoint-help/create-a-new-custom-layout-HA010079650.aspx
How to put boarders how to insert tables how to create wordart how to change paper orientation how to save documents
to create border, insert tables
click on Insert
to change orientation, click
page layout.... and then orientation
2answers
Facebook layouts
There are many browser plugin apps out there that allow you to add layouts to your facebook account but the best out there right now is called PageRage. Its the easiest to use and their designs are very nice and NOT cheesy looking. They also give you the option to create layouts and share them on their site. Check it out: www.pagerage.com 87558048-c919-4c66-8c72-d5681ddceb44 1.03.01
I loaded MS Office 2003 on a new laptop running Windows 7, only to find that Word opens as a blank page with no toolbars, rulers etc - only the writing area. Excell works ok
The Word 2003 Window When Word is first started, a new blank page titled Document1 is opened automatically. This is a fresh page where you can begin typing a new document.
  • At the top of the window is a row of menus, including File, Edit and View.
  • Below that row of menus is a row of buttons for various tools (collectively called the "toolbars") to use in creating and editing your document.
Layouts in Word 2003
Normal - Normal is the default Word 2003 view. It shows just the text that you are working on, without margins or header and footer information. It doesn't differentiate between different pages of text.
Web Layout - The Web Layout displays the document as if it were a web page
Print Layout - The Print Layout shows the entire page you are working on, including margins, header and footer information. It shows the layout of the text on the page the way it would be displayed if printed.
Volume buttons and mute/unmute buttons don't work
First open the Control Panel -> Keyboard Layout. Look for the dropdown list for different keyboard models. Scroll to the Dell models and try e.g. the Dell Mulimedia USB Keyboard layout. Stop the GUI with Ctl+Alt+Return, login again and maybe your multimedia buttons will work now.
and for more info contact http://tinyurl.com/m7ghqz
If there is no keyboard layout that fits your needs, you may download the programs keytouch and keytouch editor, which are very helpful creating your own layout.
8helpful
Make personal layout for friendster
i want to create my own friendster layouts but i dont know wer can i start
Div layer style
Select Insert > Layout Objects > Div Tag
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
