Question about SAMTRON 55V 15" CRT Monitor
Monitor how to repair a monitor with no power?
  • ronnel Mar 06, 2008
    thanks for the idea...
First u cheack ur power code. if ur power code is ok then u cheack ur monitor in cold test in power supply section.
Posted on Mar 05, 2008
  • 151 Answers
You can do cold testigh.by checking components.Before this you should know what is problem and which section it is related.
Posted on Mar 04, 2008
Dell stuck in power safe mode
A blinking power light is not indicating power safe mode, it indicates a failure of the power supply board in the monitor. Here is a link to repair guides that show how to open and repair the power supply boards in the Dell E173 series of monitors;
http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/
I hope this helps,
Apr 08, 2012 | Dell E173FP 17" LCD Monitor
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Monitor turns on then turns off
The most common cause of power issues with this unit are capacitors on the power supply board. This is an easy repair. Here is a link to a repair guide with full instructions showing how to open the monitor and what to look for and replace to rebuild the power supply board and revive the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps.
Dec 27, 2010 | ViewSonic VX2235wm LCD Monitor
I have a L227WTG and it will noit turn on, power button just keeps flashing and will not tuirn on the monitor. Help?
Unhook the monitor from the pc. Then go ahead and turn on the monitor. If the same thing happens then its an issue with the monitor and the monitor would have to be replaced. If the monitor turns on after unhooking it from the pc then its an issue with the pc.
Sep 22, 2010 | LG 22" FLATRON LCD Monitor
No power for IBM monitor model 6332-4CE
Your monitor power section has been faulty. so pls repaired it from service center.
Mar 24, 2010 | IBM E74 17" CRT Monitor
Lp2207 monitor is making a hissing sound
Your monitor is repairable, we have a repair service that can repair the power supply board in your monitor for $30 plus shipping. Let us know if you are interesrted in the repair at tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Jan 10, 2010 | Computers & Internet
Power light was blinking took a long time to turn on, now power light does not blink or go solid and screen does not work
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com This model is on Monitor repair page #2 We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Light flashing
Try another monitor on your computer to make sure that your computer is booting up properly.
If your running into the same problem with a known good working monitor then the computer is the problem.
If the known working monitor turns on then you know the original monitor is bad.
Sep 03, 2009 | Gateway FPD1975W 19" LCD Monitor
No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Samsung SyncMaster 920NW Monitor
ViewSonic Va 912B no power light, no display
Your power suplly is blown you can repair if you know alittle about repair can use a soldoring iron. You have to take the back apart and look at power supply. Look for blown caps they show raised tops bubbling on top. If you can't repair I do repair of monitor for the schools where I live if you don't want to try and repair it cantact me I will pay for shipping for parts. stabelable@q.com
Good Luck.
Mar 16, 2009 | ViewSonic VX910 19" LCD Monitor
SAMTRON 55V 15" CRT Monitor Logo
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
