Question about Symbol LS9208 Hands Free
Using Y Cable, LS9208 Prefix appears along with I 2of 5 data (does not happen with USB cable)
25-62417-20 Y cable with LS 9208 hooked up to keyboard into PS2 on PC, and programmed for scanning I 2 of 5 bar codes... prefix is present, and have been unable to find scan sheets to remove the prefix. Any ideas? Interesting that with a USB cable plugged into the same scanner, and into the PC, this prefix does not show up. We have setups in the field with both Y cables and USB cables, and before spending money on removing the Y cable setups, I wanted to know if there is a scanning solution to fix the Y cable / Prefix problem.
Note, identified prefix as follows: hooked up Y cable and scanner to a VT terminal to see prefix, and we actually saw the special characters. On a PC, while the characters did not actually show, the scanner reacted by advancing on a menu driven screen by at least 2 returns - which I believe was related to the prefix echoing to the screen along with the actual I 2of 5 data from our scanned barcode label. Again, the Y cable setup was the only scanning issue with the LS9208 (PC and VT). The USB cable setup worked w/o a hitch on a PC.
    Problem Solver:
  • 13 Answers
Hi
easy to remove the code. I can send emails with setting
Roberto
Posted on Dec 17, 2008
  • pierre_ouell
    pierre_ouell Aug 07, 2012
    can you send me the email for removing this "|" as a prefix
  • pierre_ouell
How to solve midi connectivity issue with Yamaha keyboard?
You will need to send it in for repair is my assessment.
Mar 03, 2017 | Yamaha Audio Players & Recorders
It scans 'k' at start with upc code
It sounds like the scanner has the Symbol Code ID character enabled and you are scanning a GS1-128 (formerly known as UCC/EAN 128) code. You can disable this by scanning the Symbol Code ID None barcode from Adobe page 211 of 460 (Chapter 12 page 3) of the LS9208 Product Reference Guide. https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/6083309a.pdf
Apr 18, 2014 | Zebra LS 9208 Omnidirectional Projection...
I need cables for a sony cyber shot dsc-s650
Hi.here is the link that you can buy it directly from eBay...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Brand New For Sony CyberShot DSC-S650 Camera Compatible USB Cable Features:
  • Brand New Sony Compatible USB Data Cable
  • The USB port transfers data between your digital camera to your PC or laptop. This USB cable is a must needed accessory along with your digital camera.
  • Compatibility: PC & Mac USB 1.0, 1.1,& 2.0 devices
  • Support Data transferring up to 480Mbps
  • Color: Black
  • Length: 5ft
  • Weight: 2 oz
Package Included:
  • 1 x Brand New USB Data Cable For Sony Digital Camera/DSLR
http://cgi.ebay.com/Sony-CyberShot-DSC-S650-Camera-Compatible-USB-Cable-/270724518269?pt=Camera_Cables_Cords&hash=item3f0870517d
Jul 18, 2011 | Sony Cameras
I have this samsung mp3 YP-U3, it was working months before and out of a sudden it just couldn't be recognized and it became 'unknown device'' It became worse till my laptop doesn't appear anything if I...
It could be a problem with the cable.
Are you using the same cable you have all along?
One of my players works perfectly well on one cable, bit not on another, although that cable works perfectly on another player.
Also, the cable may be faulty, and not making a data connection, though still charging.
Try a new cable.
Feb 08, 2011 | Samsung YP-T8 Digital Media Player
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
I have Symbol LS9208 barcode scanner, but I don't have any cables. I need schematics of USB or RS232 cable for this scanner.
You'll never be able to make the appropriate cables - and Motorola (they bought Symbol) no longer publishes schematics for cables. Contact the Motorola helpdesk at 1-800-653-5350
Oct 28, 2009 | Symbol LS9208 Hands Free Barcode Scanner
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How...
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Jul 13, 2009 | Symbol LS 2208 Barcode Scanner - P/N...
MANUAL FOR KEYBORD 5188
Type 5C Keyboard to USB Adapter
Operation Manual
Type 5C Keyboard to USB Adapter 5188
TYPE 5C KEYBOARD TO USB ADAPTER Page 1
This equipment generates, uses, and can radiate radio frequency energy and if not installed and used in accordance
with the instruction manual, may cause interference to radio communications. It has been tested and found to
comply with the limits for a Class A computing device in accordance with the specifications in Subpart J of Part 15
of FCC rules, which are designed to provide reasonable protection against such interference when the equipment is
operated in a commercial environment. Operation of this equipment in a residential area is likely to cause
interference, in which case the user at his own expense will be required to take whatever measures may be required
to correct the interference.
Contents
Chapter Page
1. Specifications 2
2. Introduction 3
3. Installation 3
4. Technical notes 3
5. Part Numbers and Accessories 4
1. Specifications Compatible with:
Sunä Type 5C keyboard and mouse (includes Sun Type 6 keyboard)
Ultra Spec Server Control Switch, P/N 5185 or 5195
Sun Sunblade 100 workstation
USB compliant PC workstations (a USB compliant operating system which supports the USB HID 1.1
device class specification is required)
Power:
USB bus powered device. Current load is 100 mA max (adapter only). If also powering Type 5C keyboard
and mouse requires an additional 400mA max.
Size:
4.0” x 2.4” x 1.0”
Shipping Weight:
1 lbs.
Warranty:
Ultra Spec Cables, Inc. warrants all hardware and components of the Type 5C Keyboard to USB Adapter,
with proper installation and normal use, for one year from the date of purchase.
During the warranty period, Ultra Spec Cables, Inc. will, at its option, either repair or replace hardware and
components that prove to be defective.
If your product should fail during the warranty period, phone our technical support department at 1-800-
622-2537 for warranty service (return to factory) instructions.
TYPE 5C KEYBOARD TO USB ADAPTER Page 2
2. Introduction
The Type 5C Keyboard to USB Adapter (P/N 5188) allows a USB compatible workstation to be connected to the
Server Control Switch (P/N 5185 or 5195). The adapter converts keyboard scan codes from the type 5C keyboard to
equivalent USB keyboard scan codes. The adapter also converts the mouse data to USB compatible mouse data.
The Type 5C Keyboard to USB Adapter can also be used in a standalone setup, where it is connected between a
Type 5C Keyboard/mouse and a USB based workstation.
3. Installation
3.1 Between Type 5C keyboard and workstation (standalone operation)
For all installations it is recommended that the equipment be powered off for system interconnection and/or changes
to a setup.
• Connect the port labeled To Type 5C Keyboard to either minidin8 connector on the Type 5C keyboard using a
straight through minidin8 cable (P/N 8002 or equivalent). If using a mouse, connect it to the other minidin8
connector on the keyboard.
• Connect the port labeled To Computer USB Port to any workstation USB port using a USB Type A to Type B
cable (P/N 4021 or equivalent). This type of cable is used for connecting a HUB or other device upstream to
another HUB or a host controller.
3.2 Between Server Control Switch and workstation (system operation)
to a setup.
• Connect the port labeled To Type 5C Keyboard to any Server Control switch CPU port using a straight through
• Connect the video output of the workstation to the Server Control Switch video input connector using an
appropriate cable/converter for connector and sync conversion
• Connect and power on the rest of the Server Control Switch system per the appropriate installation instructions.
4. Technical notes
Keyboard
The Type 5C Keyboard to USB Adapter emulates a Sun Type 6 USB keyboard (P/N 3201273-01) and a Sun
Crossbow USB mouse (P/N 3703632-01). The Type 5C and Type 6 keyboards match in available keys, however
several keys are relocated on the Type 6 keyboard. The adapter appropriately maps the key codes generated to the
key legends on the keyboard (i.e. all keys work the way they are labeled).
TYPE 5C KEYBOARD TO USB ADAPTER Page 3
Important Note Regarding Standby Operation:
USB supports a SUSPEND/RESUME capability that has various and incompatible implementations across differing
hardware platforms. This can affect the operation of the adapter if the workstation supports a low power or standby
mode with an incompatible implementation. Low power or standby mode is normally activated through a menu
selection (using the mouse) or by pressing the POWER key on the keyboard (upper rightmost key on both the Type
5C and Type 6 USB keyboards). For this reason, the POWER key on the Type 5C keyboard IS DISABLED when
using the adapter. In addition, it is important not to activate low power or standby mode through other means.
WHEN IN LOW POWER OR STANDBY MODE THE SYSTEM MAY NOT WAKE UP THROUGH
KEYBOARD OR MOUSE ACTIVITY, REQUIRING A HARD POWER-DOWN TO RECOVER.
In addition, the POWER key on the Type 5C keyboard does not have the capability to power-on a system as it
would when connected to a Type 5C compatible workstation (nor does a Type 6 USB keyboard have this capability
when connected to a USB workstation).
5. Part numbers and Accessories
5188 Type 5C Keyboard to USB Adapter
4021 Cable, USB Type A/B, M/M 0.5M
4022 Cable, USB Type A/B, M/M 1M
4023 Cable, USB Type A/B, M/M 2M
4024 Cable, USB Type A/B, M/M 3M
4025 Cable, USB Type A/B, M/M 4.6M
Jul 10, 2009 | HP Multimedia Cordless Keyboard/Mouse...
Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Jan 03, 2008 | Symbol LS 4000i Handheld
LS2208 barcode problem on Citrix
You you using USB versions of the device?
What device is hosting Citrix? (Maybe I should rephrase ... what computer is the LS2208 connected to and does it hold a citrix client)
Be advised that Citrix hosted on specialty devices like table pcs are finicky about the keyboard data timing (a synchronous operation)
Possibility #2 is power sag. When that scanner comes on it requires a lot of current, and often USB power (.5 amp max) isn't enough.
If you have a 15 foot USB cable on the scanner try a 6' striaght cable instead of one of the external power supply cables which provides a power pack and more power.
Nov 21, 2006 | Symbol LS2208 Handheld
Symbol LS9208 Hands Free Logo
527 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
