Question about HP Photosmart C3180 All-In-One InkJet Printer
Ink cartridge I need to know how to remove the old ink cartridge and replace it with a new one.  Lost my paperwork to tell me how.  Thanks
    Problem Solver:
  • 8 Answers
Go to www.hp.com
Click on Support and Troubleshooting
Type C3180 for Product press Enter
click on Set up and Install
Click on install the Print Cartridges
Posted on Mar 04, 2008
I just purshased a lexmart pro 705..How do you install the ink???please help
Replacing ink cartridges
Make sure you have a new ink cartridge or cartridges before you begin. You must install new cartridges immediately
after removing the old ones or the ink remaining in the printhead nozzles may dry out.
1 Turn on your printer.
2 Open the printer.
Note: The printhead moves to the cartridge installation position.
3 Press the release tab, and then remove the used ink cartridge or cartridges.
4 Install each ink cartridge. Use two hands to install the black cartridge.
Note: Install the new ink cartridges immediately after removing the protective cap to avoid exposing the ink to air.
5 Close the printer.
The setup guide is on theCD you received with the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 23, 2011 | Lexmark Office Equipment & Supplies
Lost my manual, need to change the ink cartridge, help
  1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
  2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Tells me ink cartridges are empty, even after putting new ones in. please help
Hello there,
In this case you need to please remove the new cartridges and place the old one in back and check if they are getting detected then it clearly shows that the problem is with the new cartridges. If the same persists with the old one then try ckeaning the circuit portion which is on the cartridge and the printer. and then check for the same else carrier stall needs to be replaced. Thanks and all the best
Aug 08, 2009 | Lexmark P4350 All-In-One InkJet Printer
REMOVING OLD INK CARTRIDGE
Click on this link:
Z600 Series Manual
Go to page 42. There are detailed instructions for removal and replacement of your cartridges. (With pictures.) :-)
Thanks for using Fixya.
Jun 19, 2009 | Lexmark Z640 InkJet Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
I purchased a BJC-85 color bubble jet printer in 2002. I have lost my disc to set up printer; I just received a new labtop for work and I dont want to buy another printer. Is there anyway you can take my...
The drivers that were on the CD probably won't work on your new laptop anyway. You can download the latest drivers here (use the box to select your Operating System -- Windows XP, etc.).
You can purchase ink online here. The BC-10 is a black ink only cartridge, and the BCI-10 is the replacement ink tank. The BC-11 is a cartridge with both black and color ink, and the replacement ink tanks are the BCI-11bk and BCI-11clr.
Jul 26, 2008 | Canon Office Equipment & Supplies
Ink cartridges
dear carol
try this methode
How to Replace an Empty Ink Cartridge [Edit]
If you are confused about how to do this, this will help. There are only a couple of steps.
Steps:
1. Write down the printer name and brand.
2. Remove the empty cartridge and check the writing on it. If it has any bold and big numbers on it, write these down.
3. Go to office supply store and give the clerk your notes.
4. Make sure you get the right one and take it home.
5. Open your printer's lid.
6. Take out the old cartridge and put inside a small ziploc if you want to.
7. Dispose of the old cartridge. Or if possible, have the cartridge recycled.
8. Unpack new cartridge and place inside the printer.
9. Print a test page.
10. Reconfigure printer heads for best quality.
Tips:
1. You may need a paper towel.
Warnings:
1. Wash your hands when you are done.
2. Ink may be poisonous.
oke,thanks
cropp
Mar 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
