LG Washing machine
I have a WD 8023FB washing machine which makes a loud grinding noise when it washes,more so on short cycle. I can not find the problem can you help me. Thanking you Selwyn Prasser, Bundaberg
  • diesel dog Mar 04, 2008
    I have tried this.
    Sergeant:
  • 351 Answers
Its hard to know without hearing it,is there somthing stuck between the drums try taking the belt off and turning the drum by hand.sorry i cant be of more help
Posted on Mar 04, 2008
  • Ian Greenland Mar 08, 2008
    If the noise is coming from the drum with the belt off it may be drum bearings?
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a LG front loader WD-1049C it's 6 yrs old And has just started to make a loud noise while in spin cycle All other cycles are fine
If the washer is making a loud noise the tub bearing might need to be replaced. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine
Feb 19, 2015 | LG Washing Machines
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
Hi I've got Washing Machine LG WD-8023FB front load, and SE or 5E alarm is on and machine is not working. What is that alarm for?
the alarm is indicating that the machine is not working that u should restart it or better still u check the mabual for p[roper operation
Jun 24, 2011 | LG Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Grinding noise
if the tub spins freely with no power on and makes no noise, chances are the problem is coming from the hall sensor (sensor assembly) which is located on the stator. The part costs around 20$ the part number is 6501KW2002A
Sgt 48
Jun 19, 2008 | LG WD-1280FHD Front Load Washer
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Indesit W11 making grinding noise
I think you have a drumbearing problem.:)
Dec 30, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
276 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
