Question about Casio G-Shock GW500A-1V Wrist Watch
Alarm/Beep How do I turn off the alarm that chimes every hour on the hour?
  • Anonymous Mar 17, 2014
    an alarm goes off every hour. how do i fix it?
Use the MODE button (lower left) to get into Alarm mode. Then press the RECEIVE button repeatedly, cycling through Alarm1, Alarm2, Alarm3,Alarm4, then SIG (for Signal). Press the TIME/MEMO button to togge On or Off.
David Mize
Pickerington, Ohio
Posted on Mar 06, 2008
    New Friend:
Okay people, for thoses who have the casio baby-g bg-3000. I have the solution to getting rid off the beeping of the alarm and every hour beep.
1. Press the SELECT button twice on the lower left hand side, you should see on the display AL with and alarm.
2. Press the SEARCH button, you should see a number displayed from1-5. on the far right of the screan.
3. Now as you go through the numbers look at the small circle display at alarm. If it is highlighted press the ADJUST button until it disappears. Go through all the nubers to 5 doing this method.
4. When you press the SEARCH buttin again you will find that there is no number, do not wory!! When this happens look at the small circle display at SIG. If it is highlighted just press the ADJUST button.
5. to make sure that the beeping has stopped adjust your watch before the new hour. eg 1:59. Hopefullly you will not here any beeping sounds. GOOD LUCK
Posted on Nov 18, 2012
2 Suggested Answers
SOURCE: Can't get the Hourly chime to shut off - tried
using the mode button (lower left, go to the alarm. once at this screen, hit the "12/24H" button (lower right). now hit the "adjust" button (upper left), that should toggle the hourly chime on and off. you'll see the bar next to 'SIG'. when it's lit, it's on, when it's blank, it's off.
Posted on Jun 06, 2010
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 | Watches
How to turn off the alarm?
http://www.freestyleusa.com/support/
the second window down has the buzz instructions.
in the buzz instructions
TO TURN ON/OFF THE ALARM AND
HOURLY CHIME:
1. Press S3 button to select HOME ALARM or FOREIGN ALARM to set. 2. Press S1 button to activate the alarm. Alarm indicator /
will appear.
3. Press again to activate the hourly
chime. Chime indicator will
appear.
4. Press the third time to activate both
functions. Both of the indicators
will appear.
5. Press fourth time to deactivate both
functions. Both indicators will
disappear
May 30, 2014 | Freestyle Shark Buzz Wrist Watch
How to set the alarm
These are the instructions posted on the Armitron website. I hope they help.
1. From Time Telling Mode, press 'B' twice to enter the
Alarm Mode.
2. Press 'A'. Alarm Hours flash. Press 'C' to advance the
Alarm Hour.
3. Press 'B'. Alarm Minutes flash. Press 'C' to advance the
Alarm Minute.
4. Press 'B'. Alarm Time Zone flashes. Press 'C' to select
either Time Zone 1 or Time Zone 2.
NOTE: The Alarm is available in one Time Zone only.
5. Press 'A' to end set sequence.
6. Press 'B' to return to Time Telling Mode.
ACTIVATING THE ALARM AND HOURLY CHIME
1. While in Alarm Mode, press 'C' to activate the Alarm.
The Alarm symbol appears to indicate the Alarm will
sound at the preset Alarm Time for 20 seconds or until
'A', 'B' or 'C' is pressed.
2. Press 'C' again to activate the Hourly Chime.
"CHIME" appears to indicate the Hourly Chime will sound
every hour on the hour.
3. Press 'C' again to deactivate the Alarm.
4. Press 'C' again to deactivate the Hourly Chime.
5. Press 'B' to return to Time Telling Mode.
Apr 12, 2011 | Armitron Digital Sport #40/8095SIL Watch
How do I turn off the hourly chime on the Timex 1440?
Use the mode button to toggle to the alarm function. Once at the alarm function, press start/stop. It wil turn the alarm on or off as well as the hourly chime.
Nov 10, 2010 | Timex 1440 Nylon watch
I have a xonix watch that chimes every hour, how do I stop this?
I have just bought a xonix watch and had the same problem. To get rid of this annoying beep I just had to push the 2 bottom buttons simultaneously and it was gone :D
Sep 27, 2010 | Watches
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Dont know how to turn on hourly chime timex atlantis 100
Set chime and Alarm on or off
Press MODE to select ALARM
Press START/SPLIT to change (clock sign and chime sign will appear and disappear as you keep on pressing).
Press MODE again and you are all set.
Dec 28, 2008 | Timex Atlantis 100 77517 Wrist Watch
Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
Aug 12, 2008 | Timex 27191 Wristwatch
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
Casio G-Shock GW500A-1V Wrist Watch Logo
1,683 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
