Question about Samsung HL-P5063W 50" Rear Projection HDTV
SQUEALING NOISE AND SET TURNING OFF
MY SET WILL MAKE A SQUEALING NOISE THAT USUALLY STOPS
BUT THE SET WILL TURN OFF WITH THREE LIGHTS BLINKING ON THE
FRONT PANEL: LAMP TIMER TEMP/STANDBY
THE SET IS TWO YEARS OLD
  • DaleW Apr 06, 2008
    Have heard this noise a few times on startup.  Sounds loud and scary, but stops in a couple of seconds (so far) and set does not turn off.
  • 113 Answers
The squealing noise is a defective color wheel. When the color wheel does not get up to speed (or stay up to speed) the set will shut down with the blinking you describe. You need to replace your color wheel or have a tv shop replace your color wheel.
Josh
Posted on Mar 04, 2008
I seen on another site the guy went to radio shack and bought a computer fan an he hasn't had any more heat problems this ws his 3 rd tv mabe try something lke thate to get the bulb to cool down
Posted on Mar 28, 2008
Grinding noise stops when I turn right.Is it rhe right axle?
Most likely one of the drives or cv joints
Oct 12, 2014 | Cars & Trucks
Samsung DLP not turning on
usually the colorwheel will prevent the set from powering up when all three lights blink. Diagnosis assistance is available for free from www.tvrepairworld.com
Jun 15, 2012 | Samsung HL-S5086W 50" HDTV
Toyota Tercel belts are squealing
I have been having the same problem with the alternator belt squealing, most noticeably, when using the heater fan , accelerating, turning the headlights on. I have a 1997 Toyota Tercel CE 1.5L 4cyl with no A/C. I just tightened the belt tight enough that there is no give to the belt and it does not squeal anymore.
I also used a Goodyear Gatorback from Napa belt which seems to be nice and quiet when tight enough.
Jan 30, 2012 | Toyota Tercel Cars & Trucks
My 92 4 runner makes a squealing noise when I turn. It only makes the noise when I start to accelerate in the beginning of turning. If I slow down on the gas the noise stops alot quicker, then if I keep on...
Most likely need to replace you accessory drive belt. However, before you do that make sure the tensioner is bringing adequate pressure to bear on the belt. The squealing is probably the side of the belt slipping in the metal drive pulleys.
Jan 30, 2011 | 1992 Toyota 4Runner
Squealing noise when a/c is turned on, then noise stops. Is this an a/c fan belt or something else? Would like to know what to expect when I go to auto mechanic.
Sounds like you might have a loose are worn fan belt. Specially if this is a V belt. With the hood up have someone turn the air conditioner on and watched the compressor clutch if it stops turning you might have a bad compressor. If it keeps turning in the squealing just goes away, you might just have a loose belt. Good luck.
Jun 25, 2010 | 1998 Mitsubishi Montero Sport
Belt squealing noise when heater turned on
yes...your engine belt is little bit lose that's y its causing noise...and hope when u speed up..it will stop squealing ..right?? so just tight your engine belt little bit and it will solve your problem in a min...take care n have a safe journey...n also if it help...rate it plz
Jan 23, 2010 | 2001 Hyundai Elantra
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud squealing noise
The noise is most likely the serpentine belt. Check it's condition and that of the belt tensioner. It sounds like the belt is slipping, causing the squealing noise u describe. As the belt warms up, it's getting a better 'grip' and the noise stops. Turning on the heat also turns on the a/c in newer cars, this added drag on the belt (one more component to turn, the a/c compressor) would explain why it happens when u turn on the heat. Is the belt original? If yes, it's time to change it, and check the belt tensioner to make sure it's doing it's job of keeping the belt snug on all the pulleys. Let me know how u make out.
Dec 13, 2008 | 2003 Nissan Pathfinder
Squealing noise
sounds like a loose belt!!
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
322 people viewed this question
Henry  Thomas
Henry Thomas
