Question about Panasonic KX-T7633 Corded Phone
Speed Dialing This phone has so many options that I cannot figure out something simple. It is humiliating. I think that I may have programmed in a speed dial number, but now I don't know how to, actually, speed dial. My boss is asking me to figure this out. I know when to ask for help. ha ha. Anyone want to help me with this process? Programming (to ensure that I did it correctly) and then how to speed dial.
    Scholar:
  • 38 Answers
There are actually many ways to program them, and dialing them can be different depending on the system involved.
You can have speed numbers on each extension (up to 10) and system wide (up to 1000). In addition, you can have telephone numbers associated with buttons on the phone allowing one-touch dialing.
How it is done depends on which system you have and how it was programmed by your installer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
Hoi have got speed dial on the main switchboard, so how do i do speed dial from other extensions
There is system and personal speed dials. System is programmed from the main phone and is dialed by using the AUTODIAL button and dialing a 2 or 3 digit code, depending on which system the 7730 is connected to. The other is PERSONAL speed dial, programmed on the 12 buttons on the right side of the phone. Those are programmed at each phone by using PROGRAM pressing the button and dialing an access code (usually 9) and the number then STORE.
Carl
Oct 23, 2010 | Panasonic KX-T7730 Corded Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
How to program speed dial on sony spp-a946 cordless phone
  1. Press 'PGM'- "program" button.
  2. Press "speed dial" button.
  3. Select "station # " i.e. any button from 1-9 for speed dialing.
  4. (make sure to make a note of this selected # against the corresponding tel # and /or the person's name)
  5. Dial the complete (incl. 1 for USA or country code for other country tel. #s) telephone number to be stored for the selected speed dialing station #.
  6. Press "PGM" button again to complete the storing of the tel #.
  7. Test, after dial tone, by just pressing the selected station #
Mar 13, 2009 | Sony SPP A946 Cordless Phone
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Speed Dialing
Press PROG press a speed dial button (ie 13-24) dial 9 plus the number press STORE
Carl
Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
Speed dialing
There are two types of speed dial and the programming varies with the system you have.
System speed dial is programmed from the operator or manager's phone or PC and they reside in system program 001.
Personal speed dial numbers reside in my system at location 10.
You can try PROG 10 and see what the display says.
The user manual has instructrions for programming personal speed dials.
Carl
Aug 27, 2008 | Panasonic KX-T7731 Corded Phone
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Forwarding an extension with the KX-T7630
The most apparent problem I encounter with customers when they are trying to program any speed numbers or forwarding into a Panasonic system is that they forget that they MUST enter a "9" in front of the dialing string. Also you should designate the button that you are going to use as a Forward button. Also you MUST have PERMISSION in your particular CLASS OF SERVICE for forwarding to an outside line. This MUST be programmed by your installeror it will never work.
Feb 25, 2008 | Panasonic KX-T7630 Corded Phone
Speed dialing
which model ?
generally in all cell phones v will be have speed dialing option in range costing handset also... v can set the 9 speed dialing numbers .... in which 1 speed dialing number is common that is sos(112) in samsung and motorola handsets ... common thing is may be in sony ericson also i m not sure ... in nokia handsets if we make the speed dialing option on then if we just press one number means we can call to the person ...
for ex: you may be having some person whom u will call frequently instead of selecting the number by going to phonebook if you put that number to speed dialing list means you can call them by pressing only one button...( while adding to the speed dialing list it will ask to assign the keys like 1,2,3... 9)
as every handset keypad will be having 0-9 number keys this is very useful ...
in some handsets the speed dialing option is found in phonebook & while in other it will be found in call options...
Feb 07, 2008 | Cell Phones
Setting up a speed dial
from the website:
How do I set speed dial for one of my contacts? First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign to assign it to your contact. You can now use 1-Touch Dialing for that phone number. Just press and hold that assigned one or two digit number instead of dialing the contact's entire phone number.
Sep 16, 2007 | Kyocera K10 Royale Cellular Phone
Panasonic KX-T7633 Corded Phone Logo
434 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
