Question about RCA F27442 27" TV
Television trouble okay so our RCA tv is hooked up to a dvd player and a stereo (b/c the tv speakers don't work) and we were messing around with buttons on the remote and now the dvd player works fine, we can play dvd's, but our tv has just static when you flick through the channels, and our cable is connected, so i don't know what the problem is
  • 3 Answers
Might it be that you changed the input? Try pushing the input button on the remote.
Hope it helps...
Posted on Mar 08, 2008
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
I have a 32 "
Check how you have the satellite cabled. I suspect that you have the video from the satellite to the TV but the audio cable going directly to the stereo. You probably have the DVD audio and video going directly to the TV. (I'm assuming you have the 32LA30rq and not the 32LA30rqd which has a built-in DVD and thus has the audio connection inside the TV.)
Since you don't mention which connection you are using for the DVD player and for the satellite, I will just mention the basics. If your DVD player is connected to one of the HDMI ports, that cable carries audio and video between the TV and the DVD player.
Devices that use component video cables use two separate cables. One cable with two sets of three RCA plugs carry the video; a second cable carries audio with 2 RCA plugs on each end. When you connect these, you do not have to connect the audio to the TV. (Similarly, a composite video connection can be modified for one line with the video signal going to the TV and the audio cable going to a speaker system.)
If my solution is correct, you may want to rearrange things. You can connect the satellite audio out to the TV audio in at the same location as you have the satellite video in. Then connect the TV's audio out (to the right of the component 2 in and above the coax audio out) to the stereo. Then switch the TV speakers off to use the stereo - Menu > Sound > Other Settings > Speaker On/Off. Then both devices will play either at the TV speakers or the stereo depending on the state of the TV speaker setting.
The manual is available here: http://tv.rca.com/product/manualdown.asp?modelnum=32LA30RQ .
I hope this helps.
Jan 20, 2011 | RCA Televison & Video
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Menu comes on, but tv wont display any video source.
If you hook up jacks on back for video 1 then turn tv aux to video1, Ask them do they still have owners mannel it tells you how to hook up vcr-dvds stereos
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
How do I hook up a fisher stereo to my tv so I can here the sound from my tv on my stereo speakers?
You have to have audio outputs on either your TV or VCR/DVD to input into your stereo. Look for the red and white RCA connectors. Most TV's have RCA inputs for audio and video but not always outputs. VCR/DVD players all have audio out so if you have one of these units connect a RCA cable to a input of your Fisher amp. I hope this helps
Dec 01, 2008 | Fisher Audio Players & Recorders
Sound hook up
if u have a pair of rca connectors, connect audio out of your dvd dvd receiver to audio in of your tv. they are usually red and white,, for right and left speaker.
Nov 05, 2008 | Kenwood HTB-204 System
RCA Audio Out not working?
You don't say whether you're successfully getting sound out of your stereo or not. I'll assume for the moment you are. Still getting sound out the TV is perfectly normal - RCA plugs have no mechanism for automatically disconnecting the built in speakers (in this respect, they're different from a headphone socket). Solution should simply be to press the mute button on the TV remote - although this will silence the TV speakers, you wouldn't normally expect it to affect the RCA output (failing that, just turn the TV volume control right down). A.
Apr 21, 2007 | Akai LCT2701TD Television
How to hook up a DVD player
Go to this link; http://www.amazon.com/RCA-32-Stereo-TV-F32450/dp/B00006HMDB and a short way down under "Product Details" there is a link to the product manual page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know. Please post again if you still have trouble; Hope it helps :)
Mar 29, 2007 | RCA F32450 32" TV
RCA F27442 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
