Question about Olevia LT27HVX 27 in. LCD Television
Power stopped on my new Oleiva 747i
Power will not go on although all power buttons are on, TV did work once then stop for some reason.....help if you can!!! Wife is really beating me up over this!!
Power light is on but the unit doesn't turn on. The power light does not go out wither manually or with the remote. In short, no power
    Genius:
  • 1,226 Answers
Hello!
How old is the TV?, If it is a year then maybe you can get warranty for repair or replacement. In this contact your dealer.
If it is no warranty at all, maybe you can fix the tv but it is at your burden to fix it by yourself. You can open the TV back cover and test one by one each parts that is suspected got errors. on the other hand you should do continuity test to identify error on the parts. How ever if affraid to do so, then you can let the repairman do it for you. or call the service center of your TV in your area.
Maybe this will cost you cheap in repairing this unit.
hope this help!
melnavz
Posted on Mar 04, 2008
  • Emelio Navaja
    Emelio Navaja Mar 04, 2008
    Verify also the wall outlet maybe no power on it. and the line from the wall to the input power of your tv. please see visible fuse maybe blownout.
  • Emelio Navaja
    Sergeant:
    Champion:
  • 281 Answers
Keep in mind the original 37hvs didn't have optical audio out. just pretend like it's not there.
also, there really won't be any more support for the current gen tvs. they way they are now is the way they will be. all focus is on the new lines coming out, and they are much improved.
Probale cause for oleiva not working
Probably a power spike damaged some circuit. Take it to a repair service
Oct 29, 2015 | Televison & Video
Element 32 inchTV want turn on. When hitting the power button it turns on for a quick second display the digital tv words and click back off.
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed!
Please rate if this helps! :D
Mar 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
How do I program the tv to use without cable?
1.Power on the television and press the "Menu" button on the Olevia TV's remote control.
2 Choose the "Programming" option to view all of the Olevia setup options.
3 Choose the "Channel Program" option, then select either "Antenna" or "Cable" (select "Cable" when using a satellite receiver).
4 Select "Start" and the Oleiva TV scans over all the stations it receives. Once complete, is stores the information into its memory bank, so when you attempt to change the television station you only see programs that come in clear onto the TV.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Olevia LT42HVi 42 in. LCD Television
The problem appears is u163( black ink) although
Canon MX300
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Canon PIXMA MX310 All-In-One Printer
Olevia 747i won't turn on, no blue led light? Help!
I would start with the power supply. Possibly a fuse. 9 times out of ten though if a fuse goes, something inside the set is causing the fuse to blow.
Oct 13, 2009 | Olevia LT42HVi 42 in. LCD Television
Printer won't recognise cartridges UO51
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Sep 22, 2009 | Canon Pixma MP450 All-In-One InkJet...
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vizio L32 32 in. LCD HDTV
Olevia LT27HVX 27 in. LCD Television Logo
73 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
