Question about Kenmore 24032\24036 Top Load Washer
Discharge height I am building a laundry room in the basement and I have a pvc drain pipe directly above the washer,(approx. 7 feet ) . Does the washer discaharge have the ability to pump waste water to that height?
    President:
  • Kenmore Master
  • 2,651 Answers
If its nan older model older then 5 yrs, i would say no problem. but the newr "energy efficient" machine might have a problem with that .All will be different you'll ned to check manufact spec at time of purchase( aliitle forethought so you dont do it twice)
Posted on Mar 04, 2008
I have 2goodmanGKS9 gas furnaces(propane) installed on 27 Dec 2009. Both units are working. One is in the basement adjacent to the rear outside wall. Lower unit heats about 1200 square feet. Lower...
well lets start with the 2" pvc pipe. that is a combustion air intake it does not put air into the room, i hope. this is a 90% furnace and they should have installed it that way. there should be 2 pipes to the outside the other is combustion gases. the dust problem maybe caused by the air return pulling the air to that room. the bedroom normaly does not get the trafic that the rest of the condo does.so it would not have as much dust.
Feb 10, 2011 | Goodman Heating & Cooling
My washer is leaking water out of the dispenser area . The hose for the water underneath the dispenser seems to be clogged how do i fix this?
Hi, follow the instruction below to clear the clooged hose.....
  • Pull the washer 2 to 3 feet away from the wall so you have enough room to access the drain pipe.
  • Locate the drain discharge hose where it comes out from the back of the washing machine. Typically it will be a 1 1/2-inch hose and leads to the drain in the floor, wall or laundry tub.
  • Detach the discharge hose from the drain. The hose may be secured by a squeeze clamp or screw clamp or it may just be inserted directly with no clamp. Use pliers for the squeeze clamp, screwdriver for a screw clamp or pull the hose straight up, depending on how it is secured.
  • Insert the pipe snake into the open drain until you feel the clog release. Typically this will be very close to the top rather than several feet down.
  • Check the drain hose section that is attached to the washer. If there is another clogged area, you will be able to see it; snag it with the wire and pull it out.
  • Replace the drain discharge hose into the drain and check all connections to ensure there will be no water escaping.
  • Move the washer back into place. It will now drain properly.
Nov 28, 2010 | Maytag Neptune Washer
I am going to change-out a laundry tub in my basement which is not vented. The branch arm associated with the drain appears to be 5+/- feet off the main soil stack. Should I use a cheater vent for the...
If you cannot vent it properly, the cheater vent will work fine. Cut in a tee wye (TY) withing that 5 feet and aim up. Cut a piece of pipe so it is at least 6 inches above the flood level rim of the washer, attach a female adapter and screw in the pro vent (cheater vent). Good luck.
Jan 05, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
How high can I pump up to a drain.
I have the same question....since I own a cabin with no basement floor drains. I have to pump my washer discharge to a main level drain.
To check the elevation needed, hook a garden hose to the discharge line and, after running the discharge end outside, raise or elevate the line using a line and tree branch to determine the height at which pump discharge quits. 33 feet equals appoximately 1 atmos or 14.7 psig.
Oct 05, 2009 | Roper Washing Machines
Washer outlet hose - how high can it pump?
sur thats a fine height, i wouldnt go past 8ft
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
How high can the outlet hose from a Kenmore Series 90 washing maching pump. Location is in basement with not drain but could get to basement window and then to drain. Window approx. 3 feet from top of...
The pump should be able to move waste water 3 feet above the washing machine but if that fails, then you could always buy a sewage ejector set up ( plastic barrell with internal pump and water level sensor) . Those have a highjer pupm head pressure and would be able to move water up a column further than a washing machine pump. IN all probability, you will be ok at 7 - 9 feet from floor.
Hope that helps..
Regards
Rick
Jan 26, 2009 | Washing Machines
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
WATER DRAINS
In your manual what does it say as to what height to fix the drain pipe. Try to maintain the height, approx 3 feet or so. The machine pumps the water out OVER the height..... The drain pipe shd not go straight into the drain at floor level.
Sep 01, 2007 | Admiral AW22 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
116 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
