Question about GE GSS25JEMWW Side by Side
Door handle coming off
My sidebyside is barely a year old and is only being used by one person. The door handle on the refigerator side is coming off at the top. I can see the two screws but have no idea what to do to re-tighten them. Someone said to remove the inside of the door, but I don't know how to do that either. The bottom of the handle is now beginning to loosen, too. I'm opening it by using the top of the door, but I'm afraid one of my grandchildren may visit and use the handle, pulling it the rest of the way off. I don't think this is covered by the warranty because the refrigerator was delivered (but not used) a year ago last month. What do I do? GE ZFSB27DAG SS
  • 4,102 Answers
Hi you could do the easy fix and use something like no more nails this is usually strong enough to hold handles on and alot of people do use it for these sort of jobs but if you need to tighten up the handle thats allready on then it will need you to undo the inside of door to get to the screws.
Posted on Mar 05, 2008
  • 818 Answers
Please download the documentation from this site
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=GSS25JEMWW&SITEID=DER&CHANNEL=CH0004&TABID=4
i also see this
APPROXIMATE DIMENSIONS (HxDxW) 69 3/4 in x 33 in x 35 3/4 in CAPACITY Total Capacity (cubic feet) 24.90 cu ft Fresh Food Capacity 15.33 cu ft Freezer Capacity 9.53 cu ft Shelf Area 22.40 sq ft FEATURES Defrost Type FrostGuard™ Interior Lighting Yes Upfront Electronic Temperature Controls Yes Automatic Icemaker Factory-Installed Dispenser LightTouch! Cubes; Crushed Ice & Water Dispenser Light Yes Deli Drawer Adjustable Temperature Vegetable / Fruit Crisper(s) Sealed Fresh Food Cabinet Shelves - Adjustable Yes Fresh Food Cabinet Shelves - Spill Proof Yes Fresh Food Cabinet Shelves - Total Number of Shelves 3 Glass Fresh Food Door Shelves 4 (2 Adj. w/Gal. Storage) Gallon Door Storage Yes Butter Dish Yes Dairy Compartment Yes Freezer Cabinet Shelves 5 (3 Adj.) Freezer Door Shelves 5 Fixed Freezer Interior Light Yes Freezer Storage Bin Yes Exterior Style Free-Standing ECONOMICAL / QUIET Cabinet & Door Insulation Foam Cabinet Liner ABS Door Liner ABS Quiet Package Deluxe Quiet Design NeverClean™ Condensor Yes APPEARANCE Color Appearance White on White Handle Color-Matched Premium Deluxe Adjustable Rollers Front Textured Steel Case Yes Door Stops Yes WEIGHTS & DIMENSIONS Approximate Shipping Weight 338.00 lb Net Weight (lbs.) 318.00 lb Overall Depth 33 in Overall Height 69 3/4 in Overall Width 35 3/4 in Case Depth Without Door (in.) 28 Depth with Door Open 90° (in.) 48-13/16 Depth Without Handle (in.) 30-3/4 Height to Top of Case (in.) 68-3/4 Width w/Door Open 90 Degrees Less Handle (in.) 35-3/4 Back Air Clearances (in.) 1 Side Air Clearances (in.) 1/8 Top Air Clearances (in.) 1 WARRANTY One Year Warranty Entire Appliance; Parts & Labor; In-Home Full Five Year Sealed Refrigeration System; In-Home; Parts & Laborthe last above can work for you?
Sergio
Posted on Mar 04, 2008
    Sergeant:
    Champion:
  • 281 Answers
Now you just need to buy another handle because the first one is not fixed well, it doen't cost a lot, but when you buy the handle you get free maintenance.
A loose door handle on frigidaire refigerator
There are usually some hex head screws on the upper and lower sides of the handles make sure they are tight.
Nov 29, 2014 | Electrolux Genuine Frigidaire Refrigerator...
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
My two year old admiral refigerator has air entering freezer part
lube the hinge side, sealing face of gaskets with vasoline. Heat gaskets with hair dryer then tape doors shut when hot. wait an hour before removing tape. do this on both doors.
Aug 26, 2009 | GE GSH25JFR Side by Side Refrigerator
My maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Jan 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Loose handle
yes , on most freezers the door inner panel liner needs to be removed , that will sometimes require the removal of the door gasket that may be old to the point where it to needs replacing. then finally you can get to the back side of the door and snug up the screws that hold the handle from the back. usually fine thread screws. be sure to apply loc tite and snug up good , we don't want to do this again any time soon. you can take a chance and try pulling out the handle and cutting the screws and then drill the hole in the handle out to where you see a hole in the side of the handle from the front, then counter sink the hole and use a drill screw or a small toggle bolt to resecure the handle . no real wires or refigeration tubes in the door, so its an option. good luck
Nov 24, 2008 | Freezers
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
first check with dealer about your warranty if not there are screws under the gasket to remove inside liner.
Dec 14, 2007 | GE GSS25JEMWW Side by Side
GE GSS25JEMWW Side by Side Logo
222 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
