Question about HP DeskJet 3325 InkJet Printer
Problems printing certain colors
I just bought an HP Deskjet D1420 printer, every time i try to print pictures on normal paper, the color doesn't come out how i want it, what happens is that all the reddish-brownish color come out as a magenta color
  • tsuki kazumasa Mar 04, 2008
    the printer or the cartridge?
  • 152 Answers
Cartridge jam problem replace it
Posted on Mar 04, 2008
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Wont print light flashing
Dis connect power socket, detach usb cable wait few minutes, connect power switch on printer, check for ready mode, still blinking, remove color/mono cartridges one by one verify,blink gone replace defective cartridge, if problem persists clean encoder strip,disc encoder & paper path sensor..Encoder:12_24_2011_4_31_37_pm.gifDisc encoder
12_24_2011_4_32_38_pm.jpgPaper sensor location,sensor visible from backside
Dec 24, 2011 | HP Deskjet D1420 InkJet Photo Printer
My printer doesn't print word documents (it doesn't print in black, but it does in colour), it prints everything else. I already checked the port (it's USB), changed the cartridge, uninstalled...
try the following
1.power on your peinter
2.while press and hold the power button ,open and close the top cover times.
printer pick the paper and print the test page and alignment pattern for black and color.
if any of the black or color alignment pattern is not print ,then u have to change the cartridge accordingly.
Aug 01, 2011 | HP Deskjet D2360 InkJet Printer
Installed new black cartridge in Deskjet 810C printer and after doing this it will only print in pink color. Please help.
Make certain that the cover is off the jets - if you forgot to pull the strip off or it broke leaving part of the tape on the cartridge, it won't work. Try to do a clean process on the cartridge. If that doesn't work, and you don't have another printer to try the cartridge in, return it to the place you bought it and get another new one. If the printer is printing pink, the color cartridge is probably empty also so that it cannot make black from the other colors. These sound like refilled cartridges - OEMs would have failed with some form of error code or warning.
Apr 11, 2011 | HP DeskJet 810c InkJet Printer
No color
try to head clean your printer..
follow this steps
1.click start
2.than click printers&faxes
3.right click on hp deskjet printer logo
4.select printing preference tab
5. click on maintenance
6. click on head clean
do it once and try to print some picture with best quality print setting.. and than try to print normaly again.. repeat the steps until the printer normal.
hope this help..
Apr 30, 2010 | HP DeskJet 5150 InkJet Printer
I have just replaced the color ink cartdrige in my HP Deskjet 722c printer and I tried to print a color picture in bond paper and it was a total mess
A new ink needs a little cleaning before using. Just dab lightly on a damp paper towel and look for a inch log stripe of each color on the towel. If all colors are not there it won't print very well and you should return the cartridge. Some have reported no yellow in their new cartridges.
Jan 08, 2010 | HP DeskJet 722c InkJet Printer
My printer won't print in color and the color cartridge is brand new?
ok first u check u install the black catriage. with out black catriage they can not colour print..if u have not install the black catriage and only u install the colour catriage they can not print,,that's why u check catriage. it is complusery to both catriage is install in the printer...
Apr 01, 2009 | HP Deskjet D1420 InkJet Photo Printer
HP DeskJet 3325 InkJet Printer Logo
75 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
