Question about Marantz SR-6200 Receiver
Marantz sr6200 problem
In "direct source" mode all of the speakers automatically set to "large", no problem. I've got Paradigm towers with eight inch woofers. But I don't get anything from my sub. I can only get sound from sub when "direct source" mode is off and all speakers are set to "small"
  • Bobsen Mar 08, 2008
    Me too. The problem with me is temporary solved when i switch on and off 7ch.
    How can i fix this problem. I also have problems that the volume fluctuates.
I think it may be related to set up of crossover frequencies within 'menu'. There's a menu where speaker sizes are set, as far as I remember the lowest setting suggested crossower freq for sub somewhere at 80hz as default which may be too high of you have sub.
Posted on Mar 26, 2008
Marantz sr6200
need more input.........
connected what ?
i'll give you a tip about optical sound.
if the socket glows red it's an output, if it doesn't then its an input.....optical sockets don't work two way, like some people seem to think.
other then that try selecting the optical channel using the source button.
Mar 18, 2014 | Audio Players & Recorders
My Marantz SR6200 is not playing loud and it only plays in analog and when it does and I select tuner cd or Dvd will play, there is also a little crackling on the front right speaker. please if anyone...
Hi, maybe you have speakers misconnected or speakers wiring with short circuit (joined bare cables), please check them because if this continues for a long time, your device could get damaged.
Oct 20, 2013 | Marantz SR-6200 Receiver
I have a MARANTZ SR7000 Receiver . I would like to play music CDs in direct source mode and also be able to use the subwoofer. How does one do that.
Not sure that this will be possible, direct source will cut out any changes made by the amp, and as a cd is 2 channel stereo, it wont include the subwoofer. Try some of the other settings with direct source mode.
May 03, 2011 | Marantz SR-7000 Receiver
If I purchase a sr6200 with out the remote will I be able to operate it properly?
Since the inception of AVR's and the need for user setup from a listening position the remote and a basic TV video connection are indispensable.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR6200-Receivers-manual/id/511dj786/t/2/
Given the aftermarket price of remotes, I can see why you ask.
http://remotes.com/remotes/servlet/rs?&smodel=C350&brand_pn=NAD_C350&o=c&o=c&a=Search&uid=0&m=sr6200&uuid=A13018400293721
Apr 03, 2011 | Marantz SR-6200 Receiver
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Feb 14, 2010 | Paradigm Monitor 9 Speaker
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
No sound to back channel speakers
The disc menu and sometimes the box will say if has 7.1 sound. Look under the Audio options on the disc menu.
Only your receiver will convert 5.1 sound to 7.1 if it can do so. The disc will either have the option for 7.1 or not.
Jun 12, 2017 | Marantz SR4002
Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Dec 03, 2007 | Marantz SR-6200 Receiver
Marantz SR-6200 Receiver Logo
572 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
