Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Bottom of freezer has water dripping into it
My Maytage side by side has water dripping down in the freezer and it builts up with ice on the bottom. I took off the back panel inside the freezer and the drip pan under the coils was full of ice. I thawed it out but 4 days later water was coming out of it and forming ice on the bottom of the freezer again??
Ours too. Same deal. About every second day water coming puddling out of your freezer (wide-by-side model).
This fridge has been crap since we purchased it and this is just a new problem in a series of previous ones.
  • 4 more comments
  • joeandleenie Mar 04, 2008
    Aborcass,
    Like the Fixya site says...you're a Wiz.
    I'm going to do just as you've clearly and kindly outlined.
    Can't thank you enough!
    Joe in Ottawa, Canada
  • Anonymous Jun 27, 2008
    we have ice building up in bottom of freezer and water coming from under refridg. we have leveled and cleaned with no help.
  • Anonymous Dec 06, 2008
    My freezer has more water under it than my kitchen sick. I have to put rags under it and change them every other day. I don't understand why, and I have read a few comments and i will agree this refrigerator is a piece of ****.
  • Anonymous Dec 20, 2008
    Same thing for me. Water was dripping from the area behind a slotted opening at the bottom of the inside of the freezer.
    I took the panel off the rear of the frig and found a large water line that runs from the freezer side to a pan on the other side. I took the connection off at the freezer end and it was clogged with black goo.
    We'll see if this takes care of it.
  • dingomama Feb 12, 2009
    In the freezer area under the basket, it is a solid block of ice. It goes up about 9 inches in the back and the basket drawer can't move because it and the food in it are encased in a block of ice. If I unload the freezer there is an opening at the back of the freezer with a steady stream of water dripping out. I also have water coming from under the refrigerator in sizable amounts. I have to keep a cotton bath mat under it to absorb the water because if I'm not thinking about it when I walk into the kitchen I have slipped on the tile floor because of the standing water. This was the worst purchase I have ever made, it has been one problem after another. Also my water and ice dispenser sticks and either I have ice shooting all over the kitchen or the water gets stuck on and over flows the glass and I have to open the refrigerator door to stop the water long enough to drink some and put the glass back under the dispenser until it stops. And the ice dispenser will back up into the freezer if someone uses the crushed ice mode. I thought the Maytag repair guy was supposed to be bored because their products are so good. I totally disagree. I will NEVER buy a maytag anything ever again!
  • roxana_kessl
    roxana_kessl Dec 10, 2012
    Same here..Piece of **** fridge..not only the freezer problem...but most of the plastic parts, shelves,drawers, have broken. Such poor design! Never again!
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 04, 2008
Perfect aborcass! One suggestion for idiots like me: one removes the "back" panel of the freezer from the front! :o)
Also, braided #12 wire is more flexible and easier to wrap around the heating element. Aborcass needs to go work for Maqytag and tell them how to engineer their products!
Posted on Jul 04, 2009
I have the same problem. After openeing the back panel from inside, I noticed a big ice in the drain. I removed it but pouring hot water spills the water out of the freezer and on the floor. Should I continue doing this until the drain opens up? If so, where does the water deposits? Is there a bowl or something that I need to empty out? Here is the picture of inside the back panel:
Posted on Jun 07, 2010
We had the same problem. I melted the ice with a hair dryer, poured boiling water in drain and used a pipe cleaner to snake the drain. It was still clogged. I ended up putting baking powder in the drain and pouring vinegar on the powder. This cleared the drain.
Posted on May 14, 2010
Thank you aborcass... I just priced a new frig at $1500 and came home to check to see if I could fix the leaking water from my Maytag... thanks to you, I saved $1500 with 15 mins of work and renewed my "household hero" status with my wife and kids
and thanks pequot, I would have been going to the back first if not for your post
One note for others... after I cleared the ice, used hot water, and used a small screwdriver to clear even down into the drain hole - mine was still clogged...
I then poured a little Drano into the hole... then a little more up and down with the small screwdriver and voila! the drain hole cleared up and problem solved
Thanks to everyone!
Posted on Aug 15, 2009
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Ice in bottom of frigidaire side by side freezer
clean out the drain hole with clorine bleach/blow out any gunk manually defrost unit.no hot water. no fault of siting.just a blocked vent...
Feb 08, 2010 | Frigidaire FRS26R4A Side by Side...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Ice built up on bottom of freezer then dripping down front
Probably a clogged drain. Use a pipe cleaner to unclog, then a turkey baster with hot water to clean out anything else. Then when the drain is clear, pour a weak bleach solution down the drain to kill the mold that probably caused the blockage If possible remove all food and let it sit unplugged for a day or two. This will clear some defrost problems.
Jun 22, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Exterior lights blink, ice door opens and closes on own?
im honing my psychic powers here, it a french door bottom freezer right?? Its built by samsung and the High Voltage board has failed. Had the same problem with one here
Sep 28, 2007 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
1,787 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
