Question about LG 42LC2D 42 in. LCD HDTV
Hook up vcr
I have a LG 47" flat screen. The dvd player is hooked up to AV1 and the Disnetwork Box is hooked up to AV@. there is red and white jack hook up in the bak of the RCA vcr but I do not know how to hook up to the LG screen since there is not another AV port. I have been told that first I must hook up the cable for the dish to the back of the VCR buth that signnal is not compatable. What is the best way I can hook up???
jimj
  • Anonymous Mar 15, 2014
    I have a Vizio flat panel HD TV and I bought a Funai VCR/DVD player, also a cable converter box, how do I hook all this together?
  • Anonymous Mar 31, 2014
    have cables don not know how to attach to use cd vcr with 32 lg flat screen tv
    Scholar:
  • 52 Answers
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Posted on Mar 04, 2008
Connect to a Panasonic home theatre/dvd player
You must hook up the DVD player in separate jacks into the TV with red, white, and yellow cables. To play the DVD player you must set the input in the TV menu
Dec 06, 2011 | LG 55 55LK520 LCD TV
Have a video cassette recorder & dvd/cd player. Need instrucdtions on hooking it up correctly
power off all items... do you have cable/satellite (this cable wire needs to be connected from box to the in on VCR) from the out on VCR connect back to TV...okay DVD you should have 3 cable wires (red/white and yellow) this is to be plugged into AV1 (on the back or side of TV) follow the colors... red to red and so on...note you should tune your Flat panel CH 3 along with the VCR (set it CH 3)... okay turn on all, get a tape, pop it in VCR press play... do we have a picture and sound? okay press stop.. get a DVD disk place it into DVD player press play.. using your TV remote we need to change the source from component/cable to AV1 in order to view a DVD. and change it back once finish so you can view regular TV. okay do we have picture and sound?
have fun enjoy your movie
Aug 09, 2011 | Televison & Video
Trying to hook up dvd player to a philips 27ps55-s121. I cant get it to show up on the tv screen. I dont know what channel the tv needs to be on to show the dvd. and i am unsure where what plug (cable)...
Connect one end of the VIDEO
(yellow) CABLE to the AV1 in VIDEO
jack on the back of the TV. Then connect
one end the AUDIO (red and
white) CABLES to the AV1 in AUDIO
L and R(left and right) jacks on the rear
of the TV. Connect the other end of the cables to the appropriate color on the DVD player (yellow to yellow etc.)
Press the CH + or – buttons on the
remote to scroll the channels until AV1
appears in the upper left corner of the
TV screen.
Slide the TV/VCR/ACC switch to
the VCR position.
Insert DVD into player and press PLAY.
Aug 23, 2010 | Philips Televison & Video
How do i hookup vcr to tv
The best way to hook up your VCR is to use the AV jacks (Red, White, and yellow). Plug into AV1 or Video 1 on the back of the TV. Then, plug into Red, White, and Yellow output jack on the back of the VCR. After everything is hooked up, turn your TV channel to AV1 or Video 1 to watch from the VCR.
To record, you'll have to plug your cable box or satellite box to the AV inputs ( Red, White, and Yellow) in the back of the VCR. ( The only thing is it wouldn't be in HD )
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
I just attached our HD converter box, which worked great, but now how do I hook up the PS2 and DVD player to an older model Magnovox. (Plugging the red/yellow/white cables into the side doesn't work...
by a four wy av splitter.hook every thing up in its own labeled area and click a button to switch to it or use a vcr.you can get it at radio shack.
Jun 13, 2009 | Microsoft Xbox 360 Console
AV Jacks....
Hi! Try connecting the wires to the same colour jacks and also chekc for AV button on the remote which is sue to switch the TV between AV 1 or AV 2 mode.
Thanks
Rylee
Jan 12, 2009 | Recoton Advent Advent TS2066A TV
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
LG plasma buzzing
Problem is probably with your cable box as you have confirmed that the set is working by using the dvd player, that is unless you have a bad cable for the cable box.
Aug 12, 2008 | LG Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
LG 42LC2D 42 in. LCD HDTV Logo
948 people viewed this question
