Question about byD sign d:4222 42 in. EDTV-Ready Plasma Television
Cannot access alternate video inputs
I'm trying to hook up a dvd recorder to a ByD:sign 4222. When the recorder video outputs are hooked up to either of the alternate video inputs on the back of the set, it seems there is no way to tell the TV set that it should be getting data from that input.
The only menu options I can find are for antenna or cable, there seems to be no way to select input from video 1 or video 2.
  • RickyMaveety Mar 04, 2008
    Unfortunately, I have looked all over for that submenu, and as I mentioned, there only seem to be the antenna and cable options ... nothing for video 1 or video 2.
    We also don't have the manual, so we can't look it up, and I have been all over the menu a zillion times at this point.
    I will save this manual and take it over to the house tomorrow to see if this will work. The menu choices look a little different than the one on the ByD:sign set, but it may be enough to get me where I need to go.
    Genius:
  • 1,554 Answers
There is a place in the menu where you have to tell it /define what the inputs are to be. they will have a sub menu,
I don't have the manual to show you exactly.
Posted on Mar 04, 2008
  • Karl Whisenand
    Karl Whisenand Mar 04, 2008
    it will not say video one or such , it will be to define of the inputs and then you choose what you want the input to be .
  • Karl Whisenand
    try something like
    setup
    input select
    as dell sells thes mabe this is your manual
    http://support.dell.com/support/edocs/sy...
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
How do i hook up my dvd recorder to my dvd player? where do i hook my cords to?
You need RCA cables to do this.These have red yellow and white cable ends.The yellow is for video the white is for the left speaker,red for the right speaker.Run the RCA cables from the output of you DVD player to the INPUT of your dvd recorder.Run another set of RCA cables from the output of your dvd recorder to the input of your TV.Most modern tv's have these inputs. These RCA cables can be purchased at Radio Shack or places like Walmarts.
Jan 10, 2010 | Lite On LVW-5005X DVD Recorder
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
DVD-R120 hookup for recording
You will have to hook up your recorder directly to your TV or use as a stand alone recorder.
Other possibility is to buy a 2 way video switch. This will allow you to hook up two video machines to the same input jacks on the RCVR. You just swith between the two devices manually.
Radio Shack usually have these input swithches under $30.
zucktucker
Dec 09, 2007 | Samsung DVDR120 DVD Recorder
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
byD sign d:4222 42 in. EDTV-Ready Plasma Television Logo
128 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
