Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi Model 43FDX20B Pink and Green Colors only
A little background to the issue I have. I bought my Hitachi 42" projection back in 02' and it has worked great until today. I turned it on this morning and noticed that the picture has only pink and green colors now with a little bit of a double image on certain channels.
I've heard that this could be one of the circuit boards inside and perhaps the convergence circuit is bad. Could this be the problem ? If so, I would like to repair the board myself, but don't know which convergence IC's and/or components to change on the board. Any help will be greatly appreciated.
Thanks,
Steve
  • Steve_Mi Mar 06, 2008
    Thanks team tech!! I've done a little more research from what you explained and found the part number "STK392-150". I'm going to order the parts and attempt the fix.
    Your help is greatly appreciated.
    Thanks,
    Steve
    Scholar:
  • 133 Answers
The convergence IC's you speak of are always mounted side by side and use the same #'s and are mounted on big metal heat sinks . Most start with STK392-??? . Also you may have bad resistors that are discolored and need changed as well . Some sets are protected by fuses but don't look like the typical glass fuses. They are pico fuse which could be green or yellow in color but look like resistors but do not have the color bands . Replacing the board could require a total convergence alignment. If you decide to take to a shop your avg. cost could be $250 to $300. If you do it yourself IC's and resistors or fuse would run around $50 to $70 bucks . Don't by the $9.95 IC's as they do not hold up as well . They should cost $20 to $25 apiece . Good luck
Posted on Mar 04, 2008
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
WANT 2 KNOW 43FDX20B HITACHI TV IC NUMBER NAD PART NO
You can find OEM IC's for this model (43FDX20B) from a major Hitachi parts distributor on the link below:
Hitachi 43FDX20B Replacement Part IC
If you contact them and provide the generic number or location number of the IC, they should be able to provided you with the needed parts.
Apr 02, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43fdx20b too much red, green is off
If your Hitachi TV was manufactured 15 years ago, it most likely is worn out by now.
Jun 12, 2017 | Hitachi 43FDX20B 43" Rear Projection...
Color distortion
Hi, could use a little more info, if your seeing red, blue, or green colors overlapping the image then your convergence IC`s have failed, if thats not what it`s doing please reply with more info about the symptom, video-tek
Feb 08, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Convergence IC's are at locations IK04 and IK05. There are some resistors that will be burnt up on the board as well. Replacement IC's are stk392-150, and are easily purchased, even off ebay. For the resistors you may have to get the location numbers and research the value. If you need the resistor values you can email me and I will get you the info.
Mar 04, 2008 | Hitachi 43FDX20B 43" Rear Projection...
HITACHI 42 INCH HD
Convergence Amp IC issue....originals are STK392-110..replace
W / upgrade Stk394-160E Hitachi part # CZ 01341 and check nearby resistors for overheating............................T.
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43fdx20b
well i had the same t.v. and u will have to set the picture tube which is really simple it ight seem hard but if you need an hand give me an call 1-403-362-2560 and ask for jason
Dec 17, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
98 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
