I have a Magnavox CT270mw8 A 27"Digital/Analog Television Buit in DVD Player & VCR. I can get my Dish Remote control to turnthe TV on or off. I have used all the codes in the Dish Remote user guide for Magnavox TV's. Is there a different code for the combination?
  • Anonymous Sep 06, 2008
    same issue with Tivo no remote code works
  • 4 Answers
Try Funai
Posted on Jun 19, 2008
I need the programming codes for a Dish Network remote controller and a Magnavox DVD/VCR combo player. I also need step by step programming instructions plz. Here's the specific information for both...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 28, 2014 | Televison & Video
Records & dubs but very poor resolution
You've got a Dish Network's HD DVR and a Toshiba 720P HDTV - so this part of the mix will maintain the HD pictures and high quality digital audio that you're used to seeing.
The trouble begins when you introduced the Magnavox VCR / DVD device. The highest quality video content that this device can record is the 480 type, regardless of the input or source quality - which in your case would be 720P via HDMI cables. 480 is considered "SD" or "standard definition". This is the weakest link in your setup and is responsible for your unsatisfactory results.
The Magnavox will "upconvert" to 1080 lines of resolution. The key here is the term "upconvert" True HD recordings are taken of a scene and capturing either 720 or 1080 lines of resolution in the image or video (such as a camera taking a photo or video); or recording the playback of a previously recorded 720 or 1080 lines of resolution source. Recording a 480 lines of resolution source with a an 720 or 1080 lines of resolution device will not make the image HD. The recording can not possibly be better than the original. In fact, due to losses, each generation of copy becomes worse and worse. Upconverting simply "fills in" the missing parts between the 480 source and 720 or 1080 output with what it "thinks" is missing data. The results are what you see on the screen. The original capture did not save more info that 480 lines of resolution so it is really impossible to improve it.
The recording can not ever exceed the quality of the original (the Dish Network DVR at 720 or more) and will only be as good as the weakest link (the Magnavox DVD / VCR at 480). Additionally, the moment you change from digital to analog, you lose quality instantly. Digital signals - both video and audio will always be faithfully reproduced do to error correcting technology, etc. that simply isn't available in the analog world.
You need to use a digital recorder capable of capturing and playing back of 720 or 1080 lines of resolution video and AC3 audio for optimum video and audio on a Blu Ray recorder or other device with hard drives or memory such as MP3 recorder. Otherwise you'll have to accept reduced quality of standard L & R analog audio and 480 lines of resolution of SD video. You can not expect HD audio and video if you try to save to equipment designed for SD / analog.
Dec 19, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
I have a magnavox converter box for our TV to convert Analog to digital - how do I hook up a DVD player thru it?
you cannot use the dvd player of the combo through one of these converters
however for the vcr portion here are a few easy steps
connect the magnavox converter to the IN on the back of the VCR
then tune the vcr to channel 3 or 4 whichever the converter is set to
Dec 04, 2010 | Philips Magnavox DVD/VCR Dual Player
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
TV remote codes
1000,1001,1002,1003,1004
MAGNAVOX and 0000,0001,0002,0003,0004
0057 PHILIPS and 0005,0006,0007,0008,0009
Dec 08, 2007 | Polaroid 1720-7 Remote Control
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Sep 07, 2007 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
576 people viewed this question
Top Televison & Video Experts
