Question about Hitachi 43FDX20B 43" Rear Projection Television
Hitachi Model 43FDX20B
A little background to the issue I have. I bought my Hitachi 42" projection back in 02' and it has worked great until today. I turned it on this morning and noticed that the picture has only pink and green colors with a little bit of a double image on certain channels. I've heard that this could be one of the circuit boards inside and perhaps the convergence circuit is bad. Is this the case? If so, I would like to repair the board myself, but don't know which convergence IC's and/or components to change on the board. Any help will be greatly appreciated.
Thanks, Steve
  • Steve_Mi Mar 04, 2008
    When I use the Magic Focus the screen goes to the Red screen test with no problems and then it goes to the Green screen test. The screen looks a little skewed and it doesn't finish the test(it just stops and never gets to the Blue screen test).
  • sandersdeb Jul 21, 2008
    red or pink and green on more than a quarter of the screen and some distortion of image.
  • 51 Answers
Convergence IC's are at locations IK04 and IK05. There are some resistors that will be burnt up on the board as well. Replacement IC's are stk392-150, and are easily purchased, even off ebay. For the resistors you may have to get the location numbers and research the value. If you need the resistor values you can email me and I will get you the info.
Posted on Aug 06, 2008
    Genius:
  • 1,153 Answers
What happens when you use Magic Focus after the set has been on for at least 20 min,?
Posted on Mar 04, 2008
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
WANT 2 KNOW 43FDX20B HITACHI TV IC NUMBER NAD PART NO
You can find OEM IC's for this model (43FDX20B) from a major Hitachi parts distributor on the link below:
Hitachi 43FDX20B Replacement Part IC
If you contact them and provide the generic number or location number of the IC, they should be able to provided you with the needed parts.
Apr 02, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43fdx20b too much red, green is off
If your Hitachi TV was manufactured 15 years ago, it most likely is worn out by now.
Jun 12, 2017 | Hitachi 43FDX20B 43" Rear Projection...
51F59A model hitachi rear projection tv
You may need to set your screens look at the picture when you have a real dark background if there is faint lines in the picture then the screens should be set correctly
Jun 11, 2008 | Hitachi 50V715 50" Rear Projection...
Hitachi Model 43FDX20B Pink and Green Colors only
The convergence IC's you speak of are always mounted side by side and use the same #'s and are mounted on big metal heat sinks . Most start with STK392-??? . Also you may have bad resistors that are discolored and need changed as well . Some sets are protected by fuses but don't look like the typical glass fuses. They are pico fuse which could be green or yellow in color but look like resistors but do not have the color bands . Replacing the board could require a total convergence alignment. If you decide to take to a shop your avg. cost could be $250 to $300. If you do it yourself IC's and resistors or fuse would run around $50 to $70 bucks . Don't by the $9.95 IC's as they do not hold up as well . They should cost $20 to $25 apiece . Good luck
Mar 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43fdx20b
well i had the same t.v. and u will have to set the picture tube which is really simple it ight seem hard but if you need an hand give me an call 1-403-362-2560 and ask for jason
Dec 17, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43FDX20B 43" Rear Projection Television Logo
227 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
