Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Primea ring - milk not hot
We have a new saeco primea ring, and the milk added to any of the milk drinks is luke warm at best. We found how to adjust drink temperature, and the coffee comes out nice and hot, but the "steamed" milk is literally luke warm at best. I can put my finger under the milk as it comes out and I'd guess it's coming out at about 80 deg F. Any suggestions? Does this need repair?
I had the same problem and my retailer worked it out for me when you select say cappuccino and go to the coffee quantity then the milk hold down the button that looks like a jug for over 2 seconds then the milk temperature comes up and you can adjust to low med or high now i am finally enjoying a hot drink
Posted on Oct 19, 2009
    Problem Solver:
  • 5 Answers
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Posted on Jul 30, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Just to confirm 0505's post on entering the Service Menus.
IT IS TRICKY, but keep trying and you will get there.
It is just a matter of timing :-)
I can now enter both Service Menu easily.
Thanks again to 0505 from Sweden.
Posted on Jul 31, 2008
  • 515 Answers
You have to take it to a Saeco service center, they will update the software in your machine.
Posted on Jul 11, 2008
Milk frothing is very poor. I have had the machine for 7months and at the moment the frothing has stopped and milk is warm not hot. I have tried to adjust the frothing with the white wheel bu it doesnt...
Hi. Have you removed the white wheel and tried to clean it? Check the O-rings on the frothing part for damages.
Sometimes cleaning it hasnt helped at all, The solution for it that might sound crazy =) that fixed it for me at that time was to block the 2 holes with you fingers(be carefull its hot) where the milk comes out from when you make coffee, you get a little backpressure in the milk circuit when doing it. Try 2 or more times. It helpt me.
Oct 18, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee and milk is luke warm when i make something
If you set proper menu position to "high temp", then i think one of the the boiler heater coils must be broken.
Apr 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring hot milk
Remember that the milk temp should be around 60-70c. Milk will start to boil around 80c.
You´re welcome and good luck!
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
if you go in the menu there a temperature setting for that machine pierre
Saeco Primea Touch
If you use the milk feature, please make sure that you rinse after making a milk drink or the machine will automatically request a milk cleaning cycle which is different than a rinse. For example if you make a milk drink and you skip the rinse cycle and leave the machine without rinsing for more than 20 minutes it will schedule a mandatory milk cleaning cycle.
It is okay to skip milk rinsing if you are making drink after drink as long as you rinse after the last cup.
Hope this helps you out.
Saeco's First Authorized Service Center of New York
Cerini Coffee Services
www.CeriniCoffee.com
Oct 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
812 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
