Question about Motorola Mobility i880 Cellular Phone
SD card My computer isn't reading the sd card...is there a software or program that i need for my computer to read the card? When i click on the diff drives for removable disk...it say computer not responding. My computer is pretty new....please help! This phone is driving me nuts!
  • Anonymous Nov 28, 2008
    i have what seems to be the same problem. although what i believe is the solution is to create files for each type of media e.g. music , pictures, etc. i have managed to create my music file and am up and running there. but cannot seem to create a file where the pictures i take are read by the phone off of the card. perhaps i have named the folder wrong?
  • Anonymous Nov 29, 2008
    i can place music files on the sd card but my phone will not play the music
    Brigadier General:
  • 7,752 Answers
Try doing an update of your wimdows and if that does not work try another sd card.
Posted on Mar 28, 2008
How do I recover pictures back to my power shot sd card
If your computer has a built in card reader you can put any photo back on the card from your computer by dragging and dropping the file to the drive letter that is your SD card. If you're trying to recover lost photos from a SD card Google "card recovery pro". It's a free program that will read your SD card and restore as many photo's as it can.
Sep 23, 2014 | Canon Powershot Power Shot A70 A 70 3.2 Mp...
We have downloaded the software for our MAC X so that we can load the recorded material into the program to convert to wave files. We are using a Swann USB 2.0 card reader. We can't get the computer to...
I found some useful formating instructions at http://osx.tribe.net. Note: FAT 16 only supports 2 GB or less. I had no problems reading FAT 16 formatted SD cards in Leopard. I revised the instructions a bit:
To format the SD card, you will need the path to the SD card device and the SD card device number.
1. Insert the SD Card into a card reader.
2. If you don't know how to find the device number of the SD Card, here is one way to do it:
2b. Open Disk Utility
2c. Highlight the SD Card device (upper icon), not the SD Card volume (lower icon)
2d. Click Erase at the top of the window
2e. Select Volume Format: MS-DOS (FAT) Click Erase... > Click Erase
The SD Card Volume Name will change to the UNIX device number e.g. "disk5s1". Note this number as it will change by itself to "Untitled". It is now formatted in MS-DOS FAT 32. We need to reformat it in FAT 16.
Once you have the device number of the SD Card, you need the path to the SD card device.
3. For my Mac, the path to devices is "/dev". In a terminal window: type "cd /dev" and hit the "Return" key to go to the "dev" directory. Then type "ls" (with a lower case L) and "Return" key. You should see the SD Card device number listed.
Formatting the SD Card in FAT 16:
4. In Disk Utility, highlight the SD Card device and click Unmount at the top, not Eject. The desktop icon of the SD card will disappear.
5. Go to the Terminal window. Be careful to type the following command with the correct letter case and spacing. Again, make sure you type the correct device number and path as you can very easily erase your hard drive in UNIX.
Type the command:
newfs_msdos -F 16 (path to SD Card device)/(SD Card device number)
e.g. newfs_msdos -F 16 /dev/disk5s1
and hit the "Return" key.
6. If you get just a new prompt (or a prompt with some warnings, e.g. below), the command executed successfully. You can remove the SD Card; it is now formatted in FAT 16. You can verify this in Disk Utility after mounting the SD Card.
If you get some instructions on the newfs_msdos command with a new prompt, the command did not execute. Make sure you enter the command with the correct case and spacing. Hint: to re-enter a previous command you typed, hit the up arrow repeatedly. For more information, type: "man newfs_msdos". Scroll with arrow keys. Type "q" to quit and return to prompt.
Apr 21, 2008 | Audio Players & Recorders
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
I removed my SD card without turning the power off and now I can't read the card. Can the images be recovered?
Dont worry, a good SD card recovery program can help you. you can recover your images from SD card with asoftech photo recovery program.You can see
http://www.asoftech.com/apr/
It tells the steps how to perform picture recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Mar 26, 2011 | Canon Powershot A1000IS Digital Camera
I scanned my micro sd 1gb and 2gb cards with wormblaster and now the 1 gb reads 59mb and the 2gb reads 13mb and will not format does these cards have a MBR that maybe got wiped from the scan because both...
Instructions
Things You'll Need:
* SD card slot or card reader
1. Download SanDisk Formatting Utility
2. Open an internet browser and enter the URL for the free SanDisk formatting utility into the address bar (see Resources).
3. Accept the terms of use by clicking the button labeled "I Accept" at the bottom of the page.
4. Save the executable installation file (sdfv2000.exe) to the computer hard drive.
5. Open Windows Explorer and navigate to the installation file.
6. Double-click the sdfv2000.exe file to begin the installation of the software.
7. Click "Yes" to accept the terms of use for the installation package.
8. Verify the installation location and click "Next."
9. Select a Program Folder for installation and click "Next." The progress bar will monitor the installation.
10. Click "Finish." A text file containing notes for formatting software will automatically open.
Format SanDisk
11. Click the Windows "Start" button.
12. Click "All Programs."
13. Locate and expand the Panasonic link.
14. Double-click the program entitled "SD Formatter."
15. Insert the SanDisk card into the SD slot or card reader.
16. Click the top drop-down box in the SD Formatter interface to view a list of available drives on the computer.
17. Locate the SanDisk drive and select from the drop-down options.
Click the button labeled "Format" to begin the formatting process. A notification will appear to indicate the process has finished.
Nov 04, 2010 | SanDisk 2GB microSD Memory Card
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
Wont read my camera sd card.
  1. You need to install your camera software on your new computer.
  2. Restart computer.
  3. Inset SD card.
  4. Goto start open My Computer.
  5. Look for SD card should see it under removable disk.
  6. If still not working send MSG & we will go Further.
Mar 08, 2009 | Computers & Internet
HP 2490B SD CARD
check if your SD is SD HC because it cant read HC
Nov 04, 2008 | HP iPAQ HX2490 Pocket PC
How many problems can this phone have?
Place your sd card in the slot where the sd goes and check removable disk drive. You'll see it. Mine is the H drive first have your phone format the card. email me Hoopdug2k2@msn.com.
Mar 03, 2008 | Motorola Mobility i880 Cellular Phone
Micro sd card
To read from a Micro SD card you will need a card reader that can read MicroSD cards. If your computer doesn't have one, you can go to Office Depot and buy one. They should have a few different models. If you have the adapters for your MicroSD card to convert it to a regular SD card, they have an $8 reader on sale right now. If not, they have a $35 card reader that will read almost every memory card format.
Otherwise, you'll have to go through your digital camera's software to read it.
Nov 03, 2007 | Samsung SD 616E (729507925578) Internal...
Motorola Mobility i880 Cellular Phone Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
