Question about Panasonic SC-HT680 System
How do I get my tv to play through the surround sound
I need to know how I can hear my TV set through the surround sound. When I play an audio CD and a DVD everything works fine. I just need to know how to watch a movie that is on cable TV and listen to it through the surround sound system. thank you!
  • Anonymous Dec 29, 2008
    I have a shaw hdpvr connected to my 52" samsung lcd with hdmi. I would like to know how to get my hd cable to play through my samsung 1200 home theatre
  • 47 Answers
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Posted on Mar 09, 2008
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
How to set up to my tv
Ok...sorry it took me so long to get back to you...Check the back of you tv and look for RCA jacks for audio and video out...There should be a yellow one for video..a white one for audio left(L) and a red one for audio righ(R)...you may not need the yellow one...now look for any inputs on the rear panel of the surround sound system...They can be marked (AUX)...they will work..once all of these are located...you will need an RCA patch cable long enough to reach from the tv to the surround sound receiver...once done...turn on the tv and the surround sound.With the remote from the surround sound remote...switch between the input sources..maybe (AUX) until you hear your tv sound come through...then you adjust the sound as needed...Assuming the DVD is built in to the surround sound system...your DVD sound will come back when you play DVD's...All connections and cables are color coded so you should have no problem connecting everything....Good luck....let me know how it goes,,,,I hope this was helpful....PEACE.....
Jan 05, 2012 | Audio Players & Recorders
I cant get the tv to go through the surround sound i can only get the surround sound to play when its a dvd playing do i need another wire to go from the dvd player or will it not work no matter what plz...
If you've got the Audio Input Source set as TV-Audio and it won't play as Surround Sound then you'll need to connect the Audio Out from your TV (if it has one?) to the Audio AUX IN on your LH-T360SE and change the Audio Input Source to AUX.
Jun 04, 2011 | LG LH-T360SE Theater System
I have a LG47" tv
Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Audio Players & Recorders
How do I turn my tv sound off so I only hear the surround sound. Both are playing at the same time. Polaroid tv and Samsung surround.
get unto the settings menu by pressing menu button and go to the audio settings and change the speaker settings to external or off.
Dec 28, 2009 | Teac PLD-100V System
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
Connect to dvd player
On the back panel of your tv you will see two audio inputs labeled AUDIO TO HI-FI. Plug your surround sound audio jacks, ( red and white ) into that. Plug your video jack ( yellow ) into what ever number input you are going to use for dvd, if needed. This will allow you to watch tv and hear it in your surround sound. You should also go to menu- then- audio option and turn off your tv internal speakers, this will allow your tv remote to control your volume of surround sound. Hope this helped.
Sep 07, 2008 | Hitachi 51F59 51" HDTV Projection...
WII audio and TV audio simultaneously
do you have surround sound, if you do you will need to plug the wii hookups into the surround sound, or plug it into the tv and shut the surround sound off.
May 31, 2008 | Nintendo Wii Console
Panasonic SC-HT680 System Logo
3,039 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
