Question about RCA P52926 52" Rear Projection Television
Visual and power problem
I have a 2002 RCA model# P52936 52" Rear Projection TV has worked flawlessly until yesterday. It works fine when first turned on but after 5 or 10 minutes it sort fizzles and turns off. Then comes back on by itself but the edges are distorted and fuzzy and once in a while will turn off and on again.
  • 116 Answers
Bad high voltage transformer. Most original transformers are not made anymore by RCA.
Posted on Mar 05, 2008
Tv turning off by itself occasionally
Just had mine repaired yesterday.
They relaced a TD4611 voltage regulator and a C2200uf 50v part.
Total including service call $188.00 in Western Canada.
Phil
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 in rear projection... start up menu always on
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Tv turns off after it gets hot
RCA TV's of that vintage are known for having bad solder joints in the power supply stages and they become very remperature sensitive.
Geno
Mar 17, 2008 | RCA P52937 52" Rear Projection Television
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA P52926 52" Rear Projection Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
