Question about Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-SD Our phone's message light is turned on and constantly blinks. How do I get it to turn off?
  • 1 more comment
  • jacoltrades Mar 03, 2008
    Solution to problem is #409.
  • Mike Tobin Nov 05, 2008
    My MSG light keeps blinking but their is no message. How do I turn it off?
  • Anonymous Mar 22, 2014
    On the stand the lights in the center(arrow &square ) blink constantly
INT # 409
Posted on Mar 11, 2008
How do I find the solution?
Posted on Nov 05, 2008
    What does # 409 mean and where is it?
2 Suggested Answers
  • 108 Answers
SOURCE: Message Light
Press " Intercom " # 4 0 9 to cancel msg lamp that was not left by voicemail or press the message lamp and when it rings to an internal phone have someone answer it and that will turn off the lamp also.
Posted on Jul 27, 2008
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
Please download me instructions on how to change time in our Toshiba Phones at work with Model No. DKT2010-SD. Also I am requesting a Manual for the Toshiba DKT2010-SD phone system. Your tech support...
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial As far as the system manual goes, I'll need to know the type of system you have. Toshiba DKT2010's work with a number fo different Toshiba systems. To find out, go to where the phone system is located and look at the top corner. It should have a number designation there such as DK 40i or DK280 etc.
Nov 08, 2010 | Toshiba DKT2010SD Phone
I have a toshiba dkt2010-sd how go i program this phone ... right now my display screen has NO.11 in the upper right hand corner and lower left corner it has CALL 11-15
What do you want to program? to get rid of blinking light press intercom and dial #409 to program display name type Intercom #620 and #621
Jan 21, 2010 | Toshiba DKT2010SD Phone
I have a toshiba dkt2010-sd that I need to mount to the wall
The base is removed and turned 180 degrees and put back on phone notice the slide tabs are in correct position and can noe be hung by screws or a wall jack. Where the cord plugs in there is a breakout tab, that is the insert to hold the reciever on the phone when hung up.
Sep 09, 2009 | Toshiba DKT-2010 Corded Phone
Message Light
press #409 to cancel message receive
press #64 follow by et\xtn on display to cancel sent message
mayb st 21 been assigned, but no body know.to check, call from all extn to displayed phone.check 1 by 1.
if light keep blinking for mic, try to change other key phone
May 27, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
Message Light
Jun 12, 2008 | Toshiba DKT-2010 Corded Phone
Changing Voice Mail Password from the TOSHIBA DKT2010-SD set
you will need to download the manuall you should be able to get it off this sight hope this is some help
Oct 30, 2007 | Toshiba DKT-2010 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
686 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
