Question about HP PSC 2210 All-In-One InkJet Printer
Alighning test I just changed my ink cartridge and it keeps printing the alighning sheet and test over and over and it just won't scan I guess.
  • 2 more comments
  • Leoc Mar 04, 2008
    My psc2210 thinks its a psc2205! This is what it reports when doing a self test - consequently it won't recognise updates to it's operating system. Otherwise, it works perfectly. I'd like it to reset to a psc2210!
    I've done all the advised rest tests - no success. Perhaps it needs a new PCB installed, and I guess that costs more than the machine is now worth!
    A real paradox! Fix or replace?
  • Anonymous Mar 05, 2008
    i used a new cartridge and now it will print from the computer, but won't print copies.
  • Rachelc123 Mar 17, 2008
    Yes, I think because my color cartridge is low, it can't perform the test. however, this has happened before and I found the solution somewhere on the web. still searching...
    Problem
    The following error message appears on the LCD panel on top of the printer after you insert a cartridge:
    Press enter to align cartridges
    . You press
    Enter
    , but the error message does not go away. The printer will not print.
    Solution
    To bypass the cartridge alignment, do the following:
    1. Press and hold the
      Setup
      button.
    2. Press the
      Options
      button. The printer should be ready to print.
    If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
    Step 1 - Check the paper
    Make
    sure the printer is loaded with clean, unused, white paper. If the
    paper is not feeding properly, check the paper path. For information
    about how to do that, see the instructions under "If the paper does not
    feed correctly" at the end of this document.
    Step 2 - Remove and inspect the cartridges
    NOTE:
    The "problem" cartridge is the cartridge indicated by the error message.
    1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
    2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge.
      Figure 1: Removing the cartridge
Problem The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected. Step 1 - Check the paper Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. For information about how to do that, see the instructions under "If the paper does not feed correctly" at the end of this document. Step 2 - Remove and inspect the cartridges
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridge c00143341.gif
Posted on Mar 17, 2008
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
Hi, Wonder can you help my printer keeps printing off test page everytime it is turned on. this is only happening since i changed the cartridge, never did this before. thanks
Your printer is printing alignment pages, because the cartridge alignment was not completed since you replaced them. Follow the below steps to complete alignment.
  1. Turn the printer OFF and then turn back ON.
  2. Wait until the alignment sheet prints out fully.
  3. Place the alignment test page over the scanner glass.
  4. Press start color scan button.
  5. The printer "power" light will start flashing, indication the alignment process.
  6. After the printer stops flashing, turn off and then ON the printer.It will not print any test pages further.
We need to run alignment test every-time while we replace ink cartridges.
Regards
Riztech
Nov 27, 2010 | HP Photosmart Premium C309A All-In-One...
When I print an excel page showing gridlines the lines are not straight but wavy and some of the numbers on the sheet are not visible
Cartridges are not alighned.
Remove one of the cartridges and insert it back.
The printer will print an alighment page. There are instructions on the page to place it on the scanner and to press the Scan button.
For alighment to be successful the printer has not to missing any ink.
Instead of removing and inserting a cartridge, you can use Maintenance tab in Printer preferencies to strat printhead alighment.
Aug 21, 2010 | HP PSC 1315 All-In-One InkJet Printer
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
Hp2210 all in one. i put a new ink carthridge in. it keeps telling to alighn carthridges. i press enter & the printer alighns the carthridge # prints the report. the printer keeps telling me to alighn...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Everytime I turn my PSC 1510 on it prints a test page, I have new cartridges in how can I stop it...it using all my ink unnecessarly:-(
yes, when you get test page face down the page on sccaner and press scan button after some time you get green light still, further u don't get test page again.
Jul 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
After putting a new black and white ink cartridge into the printer, it keeps printing the alighnment sheet everytime I turn the printer on. Ugh! What a waste of ink.
actually it is given in that allign page printout that how to stop this.
but listen the procedure.
after the allignment page is printed just place that allignment page in the scanner .the readable side of the page on the glass.then press OK/ENTER what button present in your printer.
the allignment will start.the printer will read the page.and allignment will get completed.then after u ON the printer it will not give you such problem till u replace the cartridges.
Nov 14, 2008 | HP Office Equipment & Supplies
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 950ink cartridge alignment
In my experience, the <align cartridge> happens when you change ink, has a [don't do {HP chat would be a help}] and wouldn't let you print or scan either unless completed.
normally prints a [2] sheet, then asks to scan it.
for photo quality, override isn't reccommended.
does copy work at all?
scan, save, print might work
Jun 09, 2008 | HP PSC 950 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
