Question about Lexmark X4270 All-In-One InkJet Printer
Cannot receive a fax
Hi guys
I have adsl connected to my computer etc. I am unable to receive a fax. I have a seperate line for the fax number. It is set with distinctive ring. I can call the number and it rings. There is a dial tone on the handset. I have asked a couple of people to send me a fax to test it but they tell me that they are getting an engaged signal. I have checked the lexmark troubleshooting website and all of my connections. What else can I do to fix my problem.
Thanks
Jennifer
  • lizardlounge Mar 03, 2008
    after all that it finally worked. don't ask me how. It just did
I had the same problem when i first install my fax machine and at that time I only had the black ink cartridge in the fax machine one's I installed the color ink cartridge, my fax machine started working.
Posted on Mar 04, 2008
I have a canon IR 1025IF that will not receive faxes but will send faxes
You should check your telephone and fax set up. Also check the settings on the machine to see if it is set for Manual receive or Fax/Tel, and the number or rings before pick up. If you are on an ADSL internet connection, you should fit or check that the line filter is working. The Fax line should be connected through the filter
Oct 31, 2017 | Canon Office Equipment & Supplies
Cannot receive faxes
The storm has likely damaged the phone line, or the ADSL microfilter (if you have one). Which is why it thinks a phone on the fax line is off the hook. Check your line for breaks and your ADSL filters for a blown filter.
Sep 18, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
How I can receive fax through computer with HP1312?
Hi a barati75
A fax transmission is an analogue communication that was possible on a computer with the old technology of Dial up Modems, which accessed the internet by dialling like a landline telephone. The Broadband Modems (or Modem/Routers) in widespread use today have an 'always on' internet connection and, therefore, no dialling is involved in internet access using them.
You can send a fax by dialling out on the All-in-one printer's telephone number pad. Receiving a fax automatically requires you to have the All-in-one printer's Transmission/Reception Settings set to 'Automatic'.
This fax setup requires the printer's fax cable to plugged directly into an empty Telephone Line Socket on the ADSL filter that plugs into your Telephone Wall Socket and has inputs for your Modem (or Modem/Router) and a Telephone line. If, as is common, your ADSL Filter only has a single Telephone Line Socket and you also require a telephone to be plugged into the same socket as well as the Fax Machine component of your printer, then a Telephone Line Socket Doubler must first be plugged into the Telephone Line Socket of the ADSL Filter which then receives the Fax Line into one socket and the Telephone Line into the other. Please note that every Telephone Socket in the building sharing the same circuit/telephone number must also have an ADSL filter between it and any telephonic device (Telephone/Fax Machine/Answering Machine/Stock Control linked EPOS (Electronic Point of Sale) System/Card Payment Processing Machine, etc.), in order to enable both Computer Internet Data and Telecommunications Data to share the same line without conflict.
Your question asks whether a fax can be received "through" the computer. The above description enables your printer to send and receive faxes 'independently' of the computer while simultaneously providing the computer with printing, scanning and copying functions. For faxes to be sent and received via the computer, software is required. The simplest and most efficient of which is Efax (Electronic Fax (available from www.efax.com) and other similar software available from a variety of suppliers. This software enables the user to send any document or image stored on the computer by fax (without first having to print it) and to receive faxes, at any time, in the form of attachments to e-mails that the software opens, usually as a non-editable PDF or other similar secure Document Format. Faxing a physical document via Efax requires the user to scan the document and save it on the computer first, before sending it.
A combination of a Standalone Fax function setup using ADSL Filters and Socket Doublers + Efax gives the user optimum flexibility in sending and receiving faxes.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment/Clarification Request to this Question.
Thanks for using FixYa
Sep 15, 2011 | HP LaserJet CM1312 All-In-One Printer
Printer will not fax I have dsl modem for computer
Hi
If you have ADSL modem for the internet, and same line you connected with Fax then you will need to ADSL splitter to split your adsl line, get the ADSL splitter in market. in splitter you get one male pine or two female pine, male pin you connect the main switch where the connect is come, one female is ADSL there your connect your modem, and other female pin you connect you fax and try. your fax and internet will work both at a time.
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Unable to receive fax
Condition 1 - Whn you dont have DSL line
The telephone line coming from the out is connected to Line 1 on the back of the printer and then going to any other device.
Condition 2 - If you have DSL line
Make sure that the line is coming in the Line 1 of the printer from ADSL filter
Jan 04, 2011 | HP J3680 Officejet All In One Printer
Unable to receive fax data, i have it on auto anwser and fax mode. sender only gets ringtone. land line is connected to fax mach. please advise.
Test by sending fax to 1300 688 999. Results will be faxed back. Automated service. Cost of local call.
Ring your fax from your mobile when you are next to it and hear it ring and answer.
ADSL filters in place???
Nov 17, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
I can only send faxes and not receive them
As far as point 1, you might want to check out this web page at HP.com:
Faxes can be received but not sent
Point 2. I have two "out" phone ports on my ADSL modem. I use one to plug it the 6110 into the modem. I do have an ADSL filter one one of my phone jacks. but I believe the modem contains one as well for phone devices directly connected to it.
Point 3. Yes. Obviously, if you are on a phone call, you won't be able to receive a fax, but if no phone call is in progress, a fax can come in just fine. Having a fax machine is just like having more than one phone in the house.
Hope this helps. Post your results back here. Good luck.
Nov 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Brother mcf-440cn
Jacki
 Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
Oct 21, 2007 | Office Equipment & Supplies
Lexmark X4270 All-In-One InkJet Printer Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
