Question about Compaq Presario 5000 PC Desktop
Harddisk fault In my computer hard disk have a bad sector in c: how can i remove that bad sectors, kindly help me thanks
We can remove the bad sector in hard disk by using hdd rergenerator software because i remove my bad sector through this software. God Bless all of you.
Thanks
Khawar_rose
Posted on Mar 07, 2008
    Genius:
  • 1,226 Answers
Hello!
Just try scandisk, Right click your c: and then properties, in tools menu, click check disk or scandisk.
may this help.
melnavz
Posted on Mar 03, 2008
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
Tip
How to use the disk error checking utility...
As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.If you use your computer daily, you should run this utility once a week to help prevent data loss.
  1. Close all open files.
  2. Click Start, and then click My Computer.
  3. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.
  4. In the Properties dialog box, click the Tools tab.
  5. Click the Check Now button.
  6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start.
  • If bad sectors are found, choose to fix them.
  • Tip: Only select the "Automatically fix file system errors" check box if you think that your disk contains bad sectors.
    on Jun 10, 2010 | Computers & Internet
    Describe your samsung sp0822n how to removing a bed sector in hard disk
    you could run the check disk utility
    click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
    click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
    do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps
    May 07, 2011 | Samsung (SP0822N) 80 GB Hard Drive
    Wd passport have bad sectors. i want to remove it or fix it
    Assuming that the disk is viewable by the windows, you can scan, try to recover the data and mark the bad sectors with this procedure. Plug in the hard disk at the system. Open "my computer" to examine the letter that this hard disk take rom the system (g: for example). Hit start and at the run field type cmd. A new black window will appear. Type on this window chkdsk g:/f/r/x (assuming that your hard disk has the drive letter g, otherwise replace g with the proper letter) and hit the enter key.The system will do the rest in a 5 step scanning procedure. This may take long time depending on the hard disk's size and the possible data on the disk.
    This is the easiest way for scanning and marking bad sectors without using external software.
    In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
    If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    direct fixya link: http://www.fixya.com/users/technical114
    Mar 02, 2011 | Computers & Internet
    My computer HDD have bad sactors please help to remove this on
    When a hard disk has bad sectors, these sectors can be fixed by running check disk. This is a temporary fix as the hard disk is nearly worn out and it will get more bad sectors and evenually the hard disk will fail completely.
    Bad sectors occur when the magnetic oxide on the disk platters is worn out and data cannot be written or read from these sectors.
    To run check disk click Start - My Computer - right click on C Drive and click on Properties - click on Tools tab - then Check Now in Error Checking
    I suggest once this has been done, you back up your data and purchase a new hard disk ready to install Windows etc. when the hard disk fails completely. You may want to install a new hard drive before the old hard drive fails completely.
    Aug 21, 2010 | Western Digital Caviar SE WD1600AAJS 160...
    Compaq Desktop won't boot up.
    Do you have your Vista installation disc? If so, you can boot from that and then run the Windows RE troubleshooter, which should be able to test your hard drive and maybe even try to repair it.
    May 27, 2010 | HP Compaq Presario SR2010NX PC Desktop
    I have bad sectors in my hard disk what should can i do?
    There is nothing you can do about bad sectors. The Hard Drive itself, with its associated electronics, automatically maps these bad sectors and doesn't use them any more. So, the answer to your question is "NOTHING". Bad sectors may eventually make your Hard Drive unusable, and if your bad sector count is growing quickly it's time to do a complete backup and replace the drive.
    Mar 30, 2010 | Computers & Internet
    Compaq Presario 5000 PC Desktop Logo
    76 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
