Question about Canon PIXMA iP1600 Printer
Hii..please help ..i have a problem with printer canon pixma ip1000
I put new ink in my printer twice ,but it writes the ink is running low,i bought a new ink again today,but the same message appears again and the printed pages are not clear at all as if the ink is really low..does my printer drink the ink ??..i don't know what to do and i need it so much to print my research ,please please help.
Hi nana,
for this problem try uninstall the software printer and clear the catridge.after install plug the cabel printer and follow intruction.
Posted on Mar 11, 2008
Pixma 150 waste
hi
you need to buy the waste toner container (its inexpnsive, plastci container that holds waste toner
go to this site first and follow instructions on HOW TO CLEAN THE INK ABSORBER
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Feb 04, 2012 | Canon PIXMA iP1000
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
I have a Pixma IP1000 and just bought a new colored ink last night. Tried printing but magenta is not printing. Help!
Click Start, Printers and Faxes (or Printers and Devices in Windows 7), Right click on your printer (Pixma iP1000), click Properties.
Go to the Maintenance Tab, do a deep cleaning (more than once if it's still printing the missing color). Also do a Bottom Plate Cleaning if it still doesn't work.
Mar 01, 2011 | Canon Office Equipment & Supplies
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Oct 03, 2008 | Office Equipment & Supplies
Canon pixma ip1000 problem
you have to reset your printer
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Sep 26, 2008 | Office Equipment & Supplies
Canon pixma iP1000 does not give clear print
It sounds as if you need a new printhead. Try contacting Canon, who can put you in the right direction
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canaon pixma ip1000
i need driver for pixma ip1000
Sep 22, 2007 | Office Equipment & Supplies
Canon Pixma ip1000 dismantle
Depress power button while plugging the canon pixma ip1000. When you depress the power button, the printer can be used even if the in waste absorber hasn't been replaced.
Apr 15, 2007 | Cannon Canon i960 Photo Printer
Canon PIXMA iP1600 Printer Logo
67 people viewed this question
old marine
old marine
