Hello!
Make sure that the disc you use is compatible in your DVD writer, there some cases that the errors cause by the source of file being writed.
Please see also the documentation of your DVD writer.
If this not the source of the errors then maybe you should uninstall and reinstall bak the application program that you use in writing the disc., You should restart the system after uninstalling the application.
may this help.
melnavz
The files are not compatible with the CD
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
If defragmentation doesn't resolve the issue, burn your project as a
data file, and then burn your project as a data disc using Disc Copier
or Creator Classic. To create a disc image/data file:
Tip:
Either of the above options are a great way to not only back up your
projects, but make multiple copies to reduce encoding time!
this solution did nott work, programme had worrked satisfactorily for 18 months prrior to this problem
programme had worked 100% for 18months priorr to this problem
