Question about Xerox Phaser 8500N Printer
Syntax errors randomly getting syntax errors when printing from xerox 8500n - have any ideas?
    President:
  • 2,072 Answers
If I understad you correctly, you are getting the errors on your computer from the print jobs faulting out?
Let's start simple to more complicated.
I would at first try shutting down and removing power from the machine for about 10 minutes, then letting it setup. Power back on and let the machine reload its software and setups.
There are various drivers on the www.xerox.com site. You may need to switch driver types. From PS to PCL or PCL to PS. Or the driver simply may be corrupted.
You can also at the site, download the printer software and upload it to the machine to eliminate corruption, and have a fresh version.
Other slight possibilities are, have you changed the word processor your using? Such as sending pages from Word to Open Office ? the format change can cause odd problems.
A firewall issue is a slight possibility, although very unlikely.
I would start with powering the machine down, then drivers.
I suspect one of those 2 will fix your issue.
Posted on Mar 03, 2008
:I have a Xerox Phaser 8500 with the following error: 13.323.47:31989. Any ideas what this is?
This fault code is saying that the printhead reservoir thermistor circuit is open. Unfortunately, only a printhead replacement will solve this problem.
Jan 09, 2011 | Xerox Phaser 8500N Printer
Hi there i can no get my Xerox Phaser 8500N to print color what can i do?
Are you using Windows 7? If so, this is a known problem.
The xerox website says to uninstall the printer and reinstall with the correct driver, but this did not work for me.
Apr 20, 2010 | Xerox Phaser 8500/DN Printer
We have a Xerox Phaser 8500N printer. The yellow is printing out a dingy gold. I hav checked the yellow print blocks and there is plenty.
What it essentially boils down to is that you're not printing enough color. The blocks are melted into a holding bin and will discolor over time. To correct this, you will need to purge the color that is "stale". Go to this link http://www.solid-inks.co.uk/technical_support-phaser_850_860_8200.html?category_id=1 and download the pdf for your color (I would recommend downloading all four to keep on hand). You'll want to open the PDF and print 10 to 20 copies until the bad ink is replaced with fresh ink. You'll notice the color change as the ink is purged.
Jan 05, 2010 | Xerox Phaser 8500N Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Nov 24, 2008 | Xerox Phaser 8500N Printer
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
5500 xerox phaser
Check the paper path for any and all debris. Use canned air to remove any debris. Also check the paper tray guides to see if they are matched correctly.
Oct 30, 2008 | Xerox Phaser 8500N Printer
My 8500N prints reams of code instead of the jpg sent to print
First off and I am sure you have tried this, but power of then power up your printer. Just to allow it to reload the software internally.
The other thing is to change drivers. That is what is generating the code.
You can go to Xerox.com there is a varity of drivers to try. Sometimes a PS and PCL driver will intrepert differently and print code like that.
Not sure preview is where the problem is. But I am assuming it prints fine in other applications.
There is also a firmware update on the xerox.com site, you can upload the newest printer software there. Or at least start out with a clean version on your printers operating software.
I strongly suspect a driver change will help.
Mar 01, 2008 | Xerox Phaser 8500N Printer
Phaser 8500N color problem
There is a process called TEKCOLOR correction.
It is on the xerox.com site.
Search for phaser 8500 under the support, in support in the search area enter.
Solutions for Colors are Off or Wrong
This will take you through the process in the correct steps to resolve your issue
Nov 07, 2007 | Xerox Phaser 8500N Printer
I can't get rid of the margins when i print something
I'm guess you are printing from MS Word? Click File the "Page Setup" Click the layout tab the far right then go to the bottom and click borders and select the NONE option. You should have your borders removed!! =) That is if that is the type of border you are talking about.
Cheers!!
Feb 11, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser 8500N Printer Logo
215 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
