Hitachi model no 50es1k---july 1993
2 questions?
the tv when first turned on -only about top 1/3 of screen is there, the rest is black, but if there is a bright color you can see it through the black part. after about 1-2 minutes the screen is all back, the black part goes down until there is a full screen and is fine until it is turned off again for at least 15 minutes.
now the sound went out if we turn the volume up you can here the static from the speakers, but no sound-
    Genius:
  • 1,153 Answers
Loose connection on circuit board and also maybe bad caps in vertical area.
Posted on Mar 04, 2008
Plasma color TV screen developed dense black vertical line
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 21, 2009 | Hitachi SSH2442 Television
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Unstable image on television screen: Hitachi Model # 27CX3B
Check for poor soldering around Vertical Driver Ic.
Nov 11, 2008 | Televison & Video
Hitachi Projection TV model 53UWX10B
hi,I just had this problem on july 1 2008.I called hitachi at 1-800-448-2244 on july 4th.They gave me a phone number for my area,They had a repairman in my area.They sent him over on the same day.It took me about an hour,and it works great.The tv is brighter than before much better.The cost of the repair was 406.80.The service call $60.00 the repaired part $ 300.00.The GST $18.00,PST $ 28.80.Having a TV that works priceless.Good luck I hope it helps.
Jun 27, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Blue and yellow curb on top of my 43" hitachi
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 14, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
