Technics tuner sound stops and overload message displayed
  • 1 more comment
  • lalen22 Apr 18, 2008
    I have a prob whith my SA-EX320. It have worked good for one year. but now i can't have my vol at 1/4 to full. i get the messege OVERLOAD. I have Canton cinema 5.1 loudspekers and it worked before. and i did get in to the reciever and i seen a F1 T2A that looks a bit suspisius neer the powercoil. Can it be that iv'e burned it?
    My mail is lalen22@hotmail.com
  • YOYO77 Jun 20, 2008
    I have a Technics SA-GX470 Receiver and I just recently purchased it used from a pawn shop, and I am starting to receive a message on the display screen saying "overload" then the system shuts down. What does that mean?
  • nbkblood Feb 20, 2009
    mine says overload as soon as its turned on and it will also say overload without any speakers hooked up to it, but when it warms up for a few minutes it starts working , very weird..
  • 593 Answers
Make sure your speakers are 8 ohm and not 4 or 2 (some receivers cant output properly to a 4 or 2 ohm load) and phased correcty.
Posted on Mar 03, 2008
My technics receiver stop playing, and display an overload message. what do you believe the is the problem ?
If you are getting an overload problem, it indicates an output load issue. Turn receiver off! remove speaker wires from the back of the unit, this will reset the protection circuit. Now power up and turn your volume right down, If the word overload stays off it means there is a short in the wire or speaker. But! if the word overload comes on "even with the wires and speakers dis-connected" it indicates a short in one or more of the audio output ic's or transistors.
Mar 17, 2011 | Technics Audio Players & Recorders
Technics SA-GX370 amplifier
Hi
One of the amplifiers is shorted. Take to a reputable repair person or check www.micromendllc.com
May 07, 2010 | Technics SUV500 2-Channel Amplifier
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
My technics sa-dx930 receiver stops working and an error message is displayed that says "overload" when i use the "b" speakers for my patio. This is a new problem. i have had the same outside speakers,...
Hey, I own one of these systems. Whenever I touch two of the wires together (shorting it out) the system shuts down and overload appears on the display. My suggestion is too check your wiring (especially in the spliced areas) or replace the wiring to the outside speakers and try it again. If you dont want to try that, take the wires you have hooked to the A speakers and see if they will work on the B setting (a quick troubleshooting technique). Please let me know if it worked for you. Good Luck!
Sep 09, 2009 | Technics SA-DX930 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Technics SA GX490 - Overload
yes it can be fixed , the input may have shorted and is now protecting the other circuits. it will need to be looked at and tested to make the repair. so calling and probably having to take it to, an electronic repair shop will need to be done.
Dec 07, 2008 | Audio Players & Recorders
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
May 23, 2008 | Technics SA-DX930 Receiver
"Overload"
Check your wires for cross polarity
Dec 20, 2006 | Technics SA-DX940
first of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Nov 22, 2005 | Technics SA-AX710
967 people viewed this question
 Grubhead
Grubhead
