My daughters dell mp3...only can see half screen
Can anybody help me...since the jack---- at dell dont want to fix the problem..
    Genius:
  • 1,027 Answers
Contact me at mewms_14904@verizon.net and I'll see what I can do for you. Is it a software issue?, data recovery?
Posted on Mar 03, 2008
How do i fix the bottom half of my laptop screen which is all black
It is unfortunate that the bottom half of the laptop screen is black. You may try performing an LCD BIST using the below link:
http://dell.to/1irqbYp
Also try connecting an external known good monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jul 06, 2014 | Dell InspironTM 1501 Notebook
Iteddy blank screen when attempting to charge
I had exactly this problem, i found you can fix this problem by being careful you can:-
1 remove the belt clip and disconnect the battery very gently.
2 unscrew the back of the unit and remove it.
3 unscrew the circuit board, DO NOT DISCONNECT THE RED AND BLACK SPEAKER WIRE
4 where you can see the jack insert there are three pins, push these pins in gently.
5 reconnect the battery and plug in the jack, the screen should come on. If it does'nt try pushing down the pins once more gently of course, to ensure good connection to the jack.
This worked for me and only took ten minutes, good luck.
Jul 09, 2009 | Bell Technology iTeddy MP3 Player
Headphone jack is wack
if you tried switching the headphones and have same issue, only a touch of solider will fix it. Microcenter has refurbed players for CHEAP with nice lcd video screens. http://www.microcenter.com/search/search_results.phtml?sortby=pricelow&web_group=hw_mp3_players&category=KB1
May 25, 2009 | Dell DJ MP3 Player
Touch Screen does not respond after I replaced it.
hey doug,
this condition is seen mostly in when the part is bad.
I would go back in the iPod and make sure your connections are all plugged in properly. Make sure the Digitizer is plugged in secure, by unplugging it and resetting it in the plug.
Did you replace the glass and digitizer with a new part????
I would continue to contact the seller and arrange for a return.
It sounds like you digitizer could be bad.
If this helps please leave a vote
Apr 25, 2009 | Apple iPod touch
Memorex MMP8565 (1Gb MP3 wont work
This screen has a sleeper function to save power - this is normal - any key should wake it up
Feb 21, 2008 | Memorex MMP8565 MP3 Player
Dell mp3 problem
On the left side next to the jack, there is a screw. Take a small screw driver and tighten the screw. On mine, I had the same problem, then was messing around one night and discovered that the screw controlled the pins inside the jack. Hopefully that helps.
Jan 15, 2008 | Dell Pocket DJ MP3 Player
Sandisk MP3 player SDMX1 - bad headphone connector
I have the same trouble. I ended up taking the 3 screws out, then I used a flat screwdriver to pry open the end pieces. Note from the top that there is a line where the end pieces connect. Pry off both end pieces - then you can separate top and bottom. HOWEVER, once you get in, it will be apparent that this is not very hacker friendly in there. There is a daughter-board with the microphone and headphone adapter and its epoxied in there. If anyone is successful in determining how to fix the headphone jack, please add!!!
Dec 26, 2006 | SanDisk SDMX1 MP3 Player
 Grubhead
Grubhead
