Question about Sony KV-27V42 27" TV
Sound when i turn on the tv its volume is all he way down so i tun it up but when i walk even 1 foot away from the tv the farther away i walk the faster it urns down no matter how high i turn the volume up it sill goes back down. can you help me
    Scholar:
  • 133 Answers
WOW never heard this one . You might check the volume down button on the tv to see if it is depressed in . What is the model # and do you clean the picture tube with windex ? Maybe some of it has seeped down onto the control board and has gummed up the volume down button. Good luck
Posted on Mar 04, 2008
Brother sewing machine LX 2500
Walking feet attach much the same way on most machines. They can be boogers the first couple of times. It helps to tilt the foot and guide it toward the needlebar from the side in order to get the fork (if your foot has a fork--some just have a bar that sets on top of the needleclamp screw) around the needleclamp screw. In cases of extreme frustration, I've removed the needleclamp screw and then reattached it once the foot is in place.
Just use patience. If frustrated, walk away. Whatever, do not force or bend the foot in order to install.
How do attach the walking foot Brother
How to use the Brother SA140 and SA188 Even Feed Walking Foot
How to Use the Brother SA107 Walking Foot
Attaching Walking Foot
How to attach walking foot to your sewing machine Elizabeth Ruffing Art...
Problems installing my walking foot
Jun 07, 2016 | Brother Sewing Machines
Pfaff varimatic 6091 What type of walking foot can i purchase for this model and are they very expensive ?
You could probably get away with a generic walking foot. They are available in the fabric store for a little under $20. Once you use one, you will wonder how you got by without it before!! I've attached a sample of a product that would work for you. Just be sure to NOT get the "slant" walking foot. That is for the Singer machine, and they have a different setup. Enjoy!!
Amazon com Distinctive Even Feed Walking Sewing Machine Presser Foot...
Mar 10, 2014 | Sewing Machines
The needle on my consew 225 just goes up and down it seams like in it is not walking. the needle only goes up and down and the fabric stays ther anyone have any ideas??????????????
Regrettably, it sounds as if you may need to see someone who specializes in walking foot Consew machines. I could only guess here and I would have to doubt that anyone untrained could correctly repair it. There are numerous internal mechanisms that drive and time that walking foot to the feed dog, so please do not attempt it yourself. Seek professional assistance.
"it seems like it is not walking" That foot will move in time with the feed dog and if it is functioning correctly, the walking mechanism is quite noticeable and obvious.
Sorry, but if you are asking that question, the only solution past the obvious--you have not lowered the foot--is one that only a professional can correct. Sorry. . .
Sep 11, 2013 | Consew 226R-1
No motor sound with walking foot on Bernina 1031?
Keep in mind that that is not a walking foot... it's actually an even feed foot.
Approach your issue logically. Take the EF foot off and put your normal foot one. Does the sound return to normal?
If it does... keep in mind that your machine is exerting more effort to make the EF foot work. That can make a motor sound differently.
Mar 19, 2013 | Bernina Sewing Machines
Increase volume
Run a cable from "Audio Out" on your TV, to "Audio In" on your stereo.
Turn up the volume on your home theater unit.
Get hearing aids
Paint a "1" in front of the "63"
Can you not hear your TV? Is the volume supposed to go above 63? Do you have it connected to any externals like a stereo, or surround sound system? Between 0 and 63, can you turn the volume up and down freely, with no problems? We need a lot more information before we can help you out with your specific problem. Let us know and we'll get you squared away!
Jan 31, 2013 | Panasonic TC-14LA1 14 in. EDTV LCD...
My TV suddenly has a big black rectangle in the lower center part of the screen, that dissapears only for a few seconds when pressing any button. How can I remove it?
Sounds like your Closed Caption has gotten turned on. Try this solution...
1) Press the MENU button
2) Use the CHANNEL UP/DOWN to scroll to CLOSED CAPTION
3) Use the VOLUME UP/DOWN to until MODE is OFF
4) Use the CHANNEL UP/DOWN to scroll to FINISH
5) Use the VOLUME UP to save and exit.
This should make the box go away.
Good Luck.....
Jan 19, 2010 | JVC AV-27F802 27" TV
How do I adjust tension on walking belt
A good way to test your walk belt to see if it is slipping is to stand on side rails with treadmill running about 4mph and while holding onto handrails keep one foot on the side rail and put your one foot on the center of the belt in a slight stomping motion,if the belt is loose you will feel it slip. To adjust a loose belt tighten each screw at back of treadmill 1/2 tun each until the slippage goes away. Be sure not to over tighten belt as this will cause excessive wear.If the belt has shifted to one side and you need to center it, go to the side it has shifted to and turn the screw clockwise 1/4 turn at a time until it centers.
Jul 14, 2009 | Exercise & Fitness
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Front panel controls are unresponsive
Check volume up switch in front panel locked continuously. If it is not take away the remote control from the TV or remove the battery in the remote. Because maybe the remote continuously sending volume up commands. Rarely this type problem occurs through remote control also. Even problem is not sorted there is problem in EEPROM ic (memory ic). This can be sorted out by the technical persons only. I hope this useful to you.
Aug 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27V42 27" TV Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
