Try United Radio (www.unitedradio.com). I used to work at a car stereo shop and that's where we sent all our repairs. Can't remember if they do Blaupunkt. It's a little pricey but they were very professional.
That wire makes it so the unit can only be used while the Parking Brake is activated, so you cannot use it whilst mobile. Some people bypass this, depending on how it works, by Earthing it out, or taking to + 12V.
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Do you use a amplifier to power the subs? If so, the amp needs a signal to turn on. This is supplied by the blue/white wire labeled 'system remote' in pioneer radio's.
Search for the next term on this site for more information about this wire: Remote turn-on in car amplifiers is obligatory?
Ouch! It's sold as as an assembly.The part you need, the LCD screen comes with a new ribbon, although you might try AAA Camera in Fort Worth Texas. They're on Lancaster on the east side of the city.Talk to Mike...accordianman
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
