Question about Maytag MER6772 Gemini Electric Kitchen Range
MER6779BAW Range/Double Oven
The lower lement in our lower oven doesn't work despite the element having been replaced. Any suggestions?
  • Gary Davd
    Gary Davd May 11, 2010
    have u checked for power coming out of the ctrl board
I haven't checked anything but the heating element. The fault codes read F0-0, which means no fault but..... ?
Posted on Mar 04, 2008
Hi. Our belling farmhouse 900g oven is not working as it should. This is regarding the lower left (main) oven. There is no heat being generated despite the indicator light working.
I would guess Since the unit is an electric oven it could have a bad element heating element and that can be determined by testing it with a meter it if the oven on the other side has the same element you could swap the heating element and see if it works and then you'll know you have it that's about all I can suggest for such an unusual oven
Mar 17, 2018 | Cars & Trucks
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
We have a Maytag Gemini double oven. The lower element in the upper oven is not working. Tried replacing it, but that didn't work. It's getting power and everything. Any suggestions?
You may have a bad oven sensor. If you look in the oven you will see a small probe about the size of a pen that is the oven sensor. Hope this gets yu going in the right direction. Thank you for using Fix ya
Jun 24, 2011 | Maytag MER6751A Electric Kitchen Range
Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Apr 26, 2009 | Frigidaire FEB27T5D Electric Double Oven
Oven blows main switch
There is a short circuit between the lower oven control and the lower element.
Disconnect the lower element. Put electrical tape on the loose terminals and turn the lower oven on.
If it does not blow, replace the lower element with a new element.
If it does blow, Check the wiring to the lower element for continuity to the frame of the range.
If you get continuity replace the damaged wire..
Finally, check the control knob switch for continuity to ground on the frame of the oven.
Mar 20, 2009 | Ovens
Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Nov 24, 2008 | Frigidaire GLEB30T8A Electric Double Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
115 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
