Question about Sony KV-27V42 27" TV
TURN TV ON FIVE VOLT RELAY CLIKS 4 OR 5 TIMES STILL NO PIC OR SOUND
I HAVE REPLACED SCR DID NOT HELP
  • Dwight Biddle Mar 04, 2008
    when turning TV on all I hear is 5 volt relay clicks 4or 5 times
    replaced SCR still same problem.
    This is the problem I started with.
    Any help.
    Thanks
    Thomas
  • mack paulk May 11, 2010
    What was your original problem?
If ur processor has 5v vcc then set could be in protection mode.
please give me the no. of processor ic so can i help you
regards
rawan
Posted on Mar 12, 2008
My TV cliks and cliks but never turns on , What should I do?
That clicking sound you hear is your TV's power supply not getting enough current to turn on the screen. Could be as simple as a blown capacitor on the power supply board unit. Many TV repair shops just replace the whole unit, I am almost sure that is your problem with you TV as I've had the same problem with several TV's before. That clicking sound always points to a power supply gone bad.
Feb 23, 2015 | Televison & Video
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
I turned on my tv and everything was fine it started to make a little wisttling sound and all of the sudden the pic dissapeard no audio and no pic the on light stays on but nothing shows please help .
There are two possible problems. We will concentrate on one first. You say the red light stays on, and the TV will not power up. Actually this is a good sign. This TV has one bad capacitor and a one weak capacitor. The bad capacitor location is C421, which is a 200 volt 10 MF at 85 degrees. Replace with a 200 volt 10Mf at 105 degrees. The second capacitor that is weak is the C482,which is a 50 volt 4.7Mf at 85 degrees. Replace with a 50 volt 4.7 Mf at 105 degrees. This should enable your TV to come back on. If the TV will not come on we will have to replace the eeprom. At this time I believe the eeprom is fine. In either case, the capacitors will need to be replaced. Try that and let me know how you do. Thanks for asking me and show all hands of support!
May 16, 2011 | Philips Magnavox 27MS343S 27" TV
My tv wont turn on.it sounds like its going to but
The 7 blinks are an error indication that is generated by protection circuitry inside the set. A problem has been detected and the set is shutdown to prevent further damage. The cilnking is the power relay that is attempting to turn on the set. I'll look up the eror code and update this with the likely solution later today.
Dan
Nov 03, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
No picture, TV dead and the relay on the power suply cliks once
Did you replace these Items?
IC1509(V out) i
Q1505(V Pulse Buffer)
Jun 18, 2009 | Sony KP-53S75 53" Rear Projection...
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Sony TV Problem model # KV-27V42
your tv has a  short  circuit, the power supply see that and put away the polarizatio n , you have to check  if transistor of power on flyback transformer is  good
or bad - delfo
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
Sony tv, no pic or sound, lcd blinks
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Dec 31, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
RCA CHASSIS CTC195K BLOWA SCR
make sure that the scr has adequate insulation. I have run into this problem before several times, and it always comes back to the scr and heatsink. check for shorts before you plug it in. unless you have an isolation transformer, do not hook up ac powered equipment to chassis ground, as this will blow your transistor again. use dc poweered volt-ohm meter.
Jul 31, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Sony KV-27V42 27" TV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
