Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool icemaker not making ice
Ice maker is not working. Fill tube was filled with frozed ice. I thawed the part of the line I could reach in the freezer. Still no water/ice in icemaker. The light to the left of the icemaker in the freezer (where the optics are located to sense need to make more ice) is not lit. Should it be? When? Did the optics unit go bad and result in the frozen supply line, or are they 2 separate problems? Thanks for any help you can offer. Whirlpool Conquest side by side fridge model # GD25DIXHT02.
  • 8 more comments
  • duomo Mar 05, 2008
    no water into tray
  • PeeDaWee Mar 07, 2008
    My icemaker isn't making ice. We have water coming out of the refrigerator and have checked the celenoids and they're fine. We have an unersink RO syste with all new filters and we did remove the filter from the fridge.
  • TurboTammy May 11, 2008
    Our door was left open over night and all the ice in frozen together in the ice maker unit. How should I go about getting it out? I have turned the unit off on the switch by the optics.
  • dmsk Jul 22, 2008
    icemaker quit making ice. Has power to modulator tho.
  • Anonymous Aug 03, 2008
    Yes hi,My whirlpool was doing the same thing ,it was freezingup not able to put the ice cubes out.The fridge is about 3 years old.Any ideas?
  • cynthia45200 Aug 06, 2008
    infra red light is on but icemaker not making ice. I changed the water filter and cleaned the coils. There is no water in the water line but I am able to get water from the door
  • Anonymous Aug 06, 2008
    ice maker not working
  • Anonymous Mar 21, 2009
    whirlpool model ED5NHAXNL01 quit making ice. Can't tell if water line is stopped up. Can't feel any water in ice maker. How can I test water line where it enters ice maker
  • VanHalen69 Apr 11, 2009
    Mine started making a strange noise and now it doesn't make ice and sometimes water just drips down and causes icicles. I went to that fix it site but he was just spamming here for $20.00 rather than telling you what this might be.
  • Anonymous Mar 15, 2014
    I have a Whirlpool model EV170NYLQ00 J0 stand up freezer that keeps freezing up The heater is working but I noticed ice on the line on the back of the unit Is that a sign of low freon
Mine's not making ice too. You should be able to see if the infra red light is on by aiming a digital camera at it just like you can see the infra red light on your tv remote control with digital camera. Anyone want to back me up on this????
Posted on Oct 01, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Optics would not gon bad from frozen water, strictly a computer watching ice level in ice bucket. it should however be lit blinking at least, if it set ot on positoin and no indicator light is on at all sounds like a bad emiiter/ reciever.
Posted on Mar 06, 2008
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
Icemaker not working
Its probably the water tray not filling. On the back of the freezer, there should be a hose that goes into the ice maker - remove the screw that holds the tubing in place, and gently pull out the hose. Let it sit for about an hour - chances are, you stopped using a lot of ice, and the water in the fill line to the ice maker froze. Once that's thawed, water should be able to flow again.
While you're behind the refrigerator, there may be an envelope with instructions for the ice maker - specifically, how to start the cycle. After the water line has thawed, you will want to start a cycle and verify the water is flowing. You should be able to hear it flowing.
Dec 19, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice Maker has stopped working....not sure if water is reaching ice maker. Would this be a difficult fix?
Depends. Put your fingers into the icemaker. Feel for ice or water. If none, check the fill tube to ensure it is not iced up. This tube feeds the icemaker with water. If it is iced up, thaw it out. If no ice or water in icemaker then pour a cup of water into the icemaker, wait the nite to see if it drops the ice. If it does the problem is the valve behind the frig.
Feb 08, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My icemaker went on the blink, found water all over kitchen floor now it will not make ice but the freezer functions great. Model number ED2FHAXB04
Sometimes the water inlet are of an ice maker for no reason will freeze up preventing water from reaching the tray and making a mess. What will happen is the ice maker fill tube on the back of the cabinet also freezes up. As a result the icemaker tries to cycle pressure then builds up in the plastic feed line to the fill tube. This pressure build up in a very "low pressure" plastic line causes that plastic line to push itself out of the press to fit connections (fittings) at the back of the unit or under the unit. Hence the next cycle it just ports water to the now open line causing water to go to the floor instead of the icemaker.
You can locate the source of the leak by simply following the plastic fill tube and re-insert it into the fitting. You still need to find the ice build up that caused the initial leak and melt that ice buildup with a hair dryer or a fan until it is clear. Once you clear the ice blockage (near the rear of the icemaker) it should work normally again.
Feb 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 05, 2009 | Whirlpool Refrigerators
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice making feature not working
Most likely the ice fill tube has frozen up and will not allow the water to fill the ice maker. You will need to remove the icemaker (three small screws) and take a hair dryer and thaw out the fill tube. You can use a bent up coat hanger to reach in and remove some of the ice that is formed up in the tube as you thaw out the ice. Also check the Icemaker's actuator arm. This sometimes is hung up by a small piece of ice that hasn't dropped causing the Icemaker to shut off. (This is the first thing to check )
Apr 27, 2009 | Viking Professional VCBB363 Bottom Freezer...
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
2,591 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
