When it comes to
refrigerators I always have a most likely to least likely formula to try to solve the reason of why the freezer or fresh food compartment is or is not cooling properly. So knowing that the cold air comes most times from the freezer compartment I would look to see if the fan inside that compartment may just be
slowing down because it is possible there is frost building behind the freezer wall due to most likely defrost not taking place and creating a huge block of snow and ice blocking air circulation.. Ice will show on the outside wall of freezer also if possibly the defrost heater is burned out. There are so great testing tutoral'son the following links! So now having your model number that most people don't think about I will look to see just what type of defrost system your model has=>
ABB1927DE EVAPORATOR AREA and Rollers location 16 in photo. That part is your models=>
67002135 Defrost Heater
Amana, ABB1927DE User Manual
Sometimes the 67003636 Evaporator Fan Motor goes bad but thawing is more severe when the evap. fan goes bad and may be tricky
stopping and starting on its own before
true-ly burning out=>
here is a Amana ABB1927DE Wiring Diagram=>
HERE
67003426 Defrost Thermostat Hey I know there is a lot of material here so I will be here if you should have questions, Thanks,
Sea Breeze
